Hi All
Ive been running oc server v 9.0.9 for a while now with no ‘real’ issues at all… Two things…
Should I upgrade to 10, if so what should the correct path be.?
In updater I’m stuck at 9.0.9. It can’t find any updates…
Many thanks
Del
Hi All
Many thanks
Del
Hi! From what I have gathered, you won’t be able to skip any major versions. So this means that you’ll g from 9.0.9 to 9.1.6 (released yesterday May 30) and then to 10.
If you want to upgrade from 9.0.9 to 9.1.6 you need to update your repositories.
For 9.1 they are here:
https://download.owncloud.org/download/repositories/9.1/owncloud/
also take a look at this:
