Hi All,
im trying to upgrade a system to 10.0.10 and getting the following error, i have actually downloaded, unziped and cp’d over teh 10.0.10 files and left my data and config dir’s.
CentOS Linux release 7.6.1810 (Core)
PHP 7.2.14 (cli) (built: Jan 8 2019 14:05:15) ( NTS )
Server version: Apache/2.4.6 (CentOS)
sudo -u apache php /var/www/html/owncloud/occ upgrade
PHP module zip not installed.
Please ask your server administrator to install the module.
PHP module dom not installed.
PHP module XMLWriter not installed.
PHP module XMLReader not installed.
PHP module intl not installed.
PHP module libxml not installed.
PHP module mb multibyte not installed.
PHP module SimpleXML not installed.
Exception: Environment not properly prepared. in /var/www/html/owncloud/lib/private/Console/Application.php:135
Stack trace:
#0 /var/www/html/owncloud/console.php(105): OC\Console\Application->loadCommands(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#1 /var/www/html/owncloud/occ(11): require_once(’/var/www/html/o…’)
