First of all, I’ve installed OwnCloud this way:
echo 'deb http://download.opensuse.org/repositories/isv:/ownCloud:/server:/10/Ubuntu_22.04/ /' | sudo tee /etc/apt/sources.list.d/isv:ownCloud:server:10.list
curl -fsSL https://download.opensuse.org/repositories/isv:ownCloud:server:10/Ubuntu_22.04/Release.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/isv_ownCloud_server_10.gpg > /dev/null
sudo apt update
sudo apt install owncloud-complete-files
So by running apt updates it will get updated too.
This time it installed the Version 10.13.0
After that, opening the web page, a database update is waiting. It shows me the following:
ownCloud wird auf Version 10.13.0 aktualisiert.
Diese Apps werden aktualisiert:
* Activity (activity)
* Admin Config Report (configreport)
* Files (files)
* Text Editor (files_texteditor)
* First run wizard (firstrunwizard)
* Market (market)
* Notifications (notifications)
Now what happens.
- Open the page
- Click on the button to start the update.
Running and finish the update.
I get the following error message:
Doctrine\DBAL\Exception\DriverException: An exception occurred while executing 'SELECT versionFROMoc_migrationsWHEREapp= ? ORDER BYversionASC' with params ["core"]: SQLSTATE[HY000]: General error: 1812 Tablespace is missing for tablemeineCloud.oc_migrations.
Clicking on that part in PhpMyAdmin outputs the same error message.
Trying to do a repair end with:
* Warning InnoDB: Tablespace is missing for table meineCloud/oc_migrations.
* Error Tablespace is missing for table `meineCloud`.`oc_migrations`.
* Error Corrupt
Looking through all entries, only “oc_migrations” is in this faulty state. Every other entry is ok.
I’ve tried with “innodb_force_recovery” parameters to get at least an export of the content and be able to reimport it into a new entry. But no success. The error message just changes to “SQLSTATE[HY000]: General error: 2006 MySQL server has gone away”
Thy mysqldump output with innodb_force_recovery set to 4 looks like this:
Server:~$ mysqldump -u '’ -p meineCloud oc_migrations
Enter password:
– MySQL dump 10.13 Distrib 8.0.34, for Linux (x86_64)– Host: localhost Database: meineCloud
– Server version 8.0.34-0ubuntu0.22.04.1
/*!40101 SET (at)OLD_CHARACTER_SET_CLIENT=(at)(at)CHARACTER_SET_CLIENT /;
/!40101 SET (at)OLD_CHARACTER_SET_RESULTS=(at)(at)CHARACTER_SET_RESULTS /;
/!40101 SET (at)OLD_COLLATION_CONNECTION=(at)(at)COLLATION_CONNECTION /;
/!50503 SET NAMES utf8mb4 /;
/!40103 SET (at)OLD_TIME_ZONE=(at)(at)TIME_ZONE /;
/!40103 SET TIME_ZONE=‘+00:00’ /;
/!40014 SET (at)OLD_UNIQUE_CHECKS=(at)(at)UNIQUE_CHECKS, UNIQUE_CHECKS=0 /;
/!40014 SET (at)OLD_FOREIGN_KEY_CHECKS=(at)(at)FOREIGN_KEY_CHECKS, FOREIGN_KEY_CHECKS=0 /;
/!40101 SET (at)OLD_SQL_MODE=(at)(at)SQL_MODE, SQL_MODE=‘NO_AUTO_VALUE_ON_ZERO’ /;
/!40111 SET (at)OLD_SQL_NOTES=(at)(at)SQL_NOTES, SQL_NOTES=0 */;–
– Table structure for tableoc_migrationsDROP TABLE IF EXISTS
oc_migrations;
/*!40101 SET (at)saved_cs_client = (at)(at)character_set_client /;
/!50503 SET character_set_client = utf8mb4 /;
CREATE TABLEoc_migrations(
appvarchar(177) COLLATE utf8mb4_bin NOT NULL,
versionvarchar(14) COLLATE utf8mb4_bin NOT NULL,
PRIMARY KEY (app,version)
) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_bin ROW_FORMAT=COMPRESSED;
/!40101 SET character_set_client = (at)saved_cs_client */;–
– Dumping data for tableoc_migrationsmysqldump: Couldn’t execute ‘SELECT /*!40001 SQL_NO_CACHE */ * FROM
oc_migrations’: Lost connection to MySQL server during query (2013)
I don’t want to start with a clean new OwnCloud installation.
So is there a way to fix this?
EDIT: I was able to do a rollback of the entire server with a backup to a date before the update got installed. The version is now 10.12.2.1 and the server is running.
The “oc_migrations” entry in the database is still corrupt.
But: Maybe with a running server its possible to delete and rebuild this?
Operating system: Ubuntu 22.04.3 LTS
Web server: Apache
Database: libmysql - mysqlnd 7.4.33
PHP version: 7.4.33
ownCloud version: 10.13.0
Updated from an older ownCloud or fresh install: Updated from the earlier version that got rolled out over the repo. (10.12.2.1)
Where did you install ownCloud from: As described at the beginning
The other stuff in the list is currently not possible (because I get nothing more than this Database update page) or there is no visible connection to the faulty database entry.
