Upgrade to 9.1 from 9.0.2
2.
3.
ownCloud version (see ownCloud admin page):
Integrity status for oC9+
Hi. I am new to this forum software (older was better), so bear with me.
I have oc 9.0.2, what is the correct upgrade path to 9.1.0 and can I use the same apps by re enabling them? I only have contacts and calendar to worry about.
Thanks in advance for any suggestions.
if you don’t use the issue template you can delete it completely as it makes no sense to keep it if its empty.
Upgrading instructions are available in the documentation:
There you can also find the info that it is recommended to update to 9.0.4 first before upgrading to the next major release 9.1.0
