Upgrading from 10.0.9 to 10.9.1 failed with "Foreign key constraint is incorrectly formed"
Stop basic stuffs
sudo -u apache php /var/www/html/occ maintenance:mode --on
systemctl stop crond
systemctl stop httpd
backup db
mkdir -p /var/tmp/owncloudbackupfiles/db
DATE=date +%Y%m%d%H%M%S
/bin/mysqldump -u owncloud -pxyz owncloud > /var/tmp/owncloudbackupfiles/db/owncloud-$DATE.dump
backup htaccess and user ini and download the update file
cp /var/www/html/.htaccess /var/tmp/owncloudbackupfiles/
cp /var/www/html/.user.ini /var/tmp/owncloudbackupfiles/
cd /var/www
wget --no-check-certificate download.owncloud.com
Move Current ownCloud Directory
mv /var/www/html /var/www/backup_of_html_before_update
extract the new owncloud
tar -xf owncloud-complete-latest.tar.bz2
mv owncloud html
copy config.php to the new folder
cp -pr /var/www/backup_of_html_before_update/config/config.php /var/www/html/config/
check the apps are available in the new one that was available in the old one, if not available something has to copy over
ll html/apps/
ll backup_of_html_before_update/apps/
set permissions
find -L /var/www/html ( -path ./data -o -path ./config ) -prune -o -type d -exec chown root:apache {} +
find -L /var/www/html ( -path ./data -o -path ./config ) -prune -o -type f -exec chown root:apache {} +
chown -R apache:apache /var/www/html/config
chown -R apache:apache /var/www/html/data
chown -R apache:apache /var/www/html/apps
find /var/www/html -type f -exec chmod 640 {} ;
find /var/www/html -type d -exec chmod 750 {} ;
before update has to change to php 7.3 first because it is not compatible with my current version php56w (56 common removed)
yum-config-manager --disable webtatic
yum-config-manager --enable remi-php73
yum install php php-cli php-fpm php-mysqlnd php-zip php-devel php-gd php-mcrypt php-mbstring php-curl php-xml php-pear php-bcmath php-json php-intl
sudo -u apache php /var/www/html/occ app:disable files_videoplayer
sudo -u apache php /var/www/html/occ upgrade
It should update the owncloud
Failed with DB error
10:53:01 May 20, 2022 Set log level to debug
10:53:01 May 20, 2022 Repair step: Upgrade app code from the marketplace
10:53:01 May 20, 2022 Repair warning: Market app is unavailable for updating of apps. Please update manually, see https://doc.owncloud.com/server/10.9/go.php?to=admin-marketplace-apps
10:53:01 May 20, 2022 Repair step: Repair MySQL database engine
10:53:01 May 20, 2022 Repair step: Repair MySQL collation
10:53:01 May 20, 2022 Repair info: All tables already have the correct collation → nothing to do
10:53:01 May 20, 2022 Repair step: Repair SQLite autoincrement
10:53:01 May 20, 2022 Repair step: Repair orphaned reshare
10:53:01 May 20, 2022 Repair step: Repair duplicate entries in oc_lucene_status
10:53:01 May 20, 2022 Repair info: lucene_status table does not exist → nothing to do
10:53:01 May 20, 2022 Updating database schema
10:53:02 May 20, 2022 Doctrine\DBAL\Exception\DriverException: An exception occurred while executing ‘ALTER TABLE oc_persistent_locks ADD CONSTRAINT FK_F0C3D55B93CB796C FOREIGN KEY (file_id) REFERENCES oc_filecache (fileid) ON DELETE CASCADE’:
SQLSTATE[HY000]: General error: 1005 Can’t create table owncloud.#sql-4ce_bcde2a2 (errno: 150 “Foreign key constraint is incorrectly formed”)
10:53:02 May 20, 2022 Update failed
10:53:02 May 20, 2022 Maintenance mode is kept active
10:53:02 May 20, 2022 Reset log level
Operating system: centos7 - 3.10.0-693.5.2.el7.x86_64
Web server: apache httpd
httpd-tools-2.4.6-93.el7.centos.x86_64
httpd24-libnghttp2-1.7.1-6.el7.x86_64
httpd24-httpd-tools-2.4.27-8.el7.x86_64
httpd-2.4.6-93.el7.centos.x86_64
httpd24-runtime-1.1-18.el7.x86_64
httpd24-httpd-2.4.27-8.el7.x86_64
Database: mariadb
mariadb-10.1.20-1.el7.x86_64
mariadb-common-10.1.20-1.el7.x86_64
mariadb-config-10.1.20-1.el7.x86_64
mariadb-galera-common-5.5.40-3.el7.x86_64
mariadb-server-galera-10.1.20-1.el7.x86_64
mariadb-libs-10.1.20-1.el7.x86_64
mariadb-errmsg-10.1.20-1.el7.x86_64
mariadb-server-10.1.20-1.el7.x86_64
php56w-mysql-5.6.40-1.w7.x86_64
perl-DBD-MySQL-4.023-5.el7.x86_64
rh-php56-php-mysqlnd-5.6.25-1.el7.x86_64
PHP version: PHP 5.6.40 (cli) (built: Jan 12 2019 13:11:15)
ownCloud version: 10.0.9 (stable)
Updated from an older ownCloud or fresh install: update from older
Where did you install ownCloud from: download.owncloud.com
“system”: {
“instanceid”: “ockfcvhe73ml”,
“trusted_domains”: [
“1.2.3.4”,
“1.2.3.4”
“datadirectory”: “/data/owncloud”,
“overwrite.cli.url”: “https://file.mycompany.com”,
“overwritehost”: “file.mycompany.com”,
“dbtype”: “mysql”,
“version”: “10.0.9.5”,
“dbname”: “owncloud”,
“dbhost”: “1.2.3.4:3306”,
“dbtableprefix”: “oc_”,
“installed”: true,
“updater.secret”: “REMOVED SENSITIVE VALUE”,
“mail_smtpmode”: “smtp”,
“mail_smtpport”: “25”,
“ldapIgnoreNamingRules”: false,
“log_type”: “owncloud”,
“logfile”: “/var/log/owncloud/owncloud.log”,
“loglevel”: 2,
“logdateformat”: “H:i:s F d, Y”,
“logtimezone”: “Asia/Bangkok”,
“log_authfailip”: true,
“theme”: “”,
“trashbin_retention_obligation”: “auto, 30”,
“maintenance”: false,
“dbdriveroptions”: {
“1002”: “SET wait_timeout = 288000”
“integrity.ignore.missing.app.signature”: [
“theme-mycompany”
“integrity.excluded.files”: [
“core/templates/login.php”,
“core/templates/layout.user.php”,
“.htaccess”,
“.user.ini”,
“core/skeleton/Documents/Example.odt”,
“core/skeleton/Photos/Paris.jpg”,
“core/skeleton/Photos/San Francisco.jpg”,
“core/skeleton/Photos/Squirrel.jpg”
  • activity: 2.3.7
  • comments: 0.3.0
  • dav: 0.3.2
  • encryption: 1.3.1
  • federatedfilesharing: 0.3.1
  • files: 1.5.1
  • files_antivirus: 0.13.0
  • files_external: 0.7.1
  • files_pdfviewer: 0.9.0
  • files_sharing: 0.10.1
  • files_texteditor: 2.2.1
  • files_trashbin: 0.9.1
  • notifications: 0.3.4
  • provisioning_api: 0.5.0
  • systemtags: 0.3.0
  • user_ldap: 0.11.0
Are you using external storage, if yes which one:
glusterfs, I have 2 owncloud instance with balanced mariadb and glusterfs on an fs in the /data directory.
Are you using encryption: yes
Are you using an external user-backend, if yes which one: LDAP
limited to 32000 characters the paste here
I had a look in the DB:
oc_persistent_lock bigint lenght is 20, this should be int 11 maybe because the oc_filecache is int length 11??
If I change it it should fix the issue but not sure this is the right way to fix it, hopefully someone smarter than me can advise.
