cpu not at 100% all the time
cpu at 100%
ubunto 14.04
webserver version": “Apache/2.4.7 (Ubuntu)”,
Database Version": “0.system”,
“PHP Version”: “5.5.9-1ubuntu4.14”
ownCloud version": “9.1.8.2”,
updated from 8.2 to 9.0 to 9.1.8
repositories
sign in ok
none
