- Enable syncing of “hidden” files.
- Wait for the client software to complain about insufficient space even though the server has plenty of free space and the user account has an unlimited quota.
- Under Activity, Not Synced tab, files named “.htaccess” are getting that quota exceeded message.
Everything syncs, or if there is a problem with .htaccess files, the error given reflects this.
Everything does not sync.
CentOS Linux release 7.4.1708 (Core)
Apache Release 67.el7.centos.6
sqlite3 9.1.5.2
Version : 5.4.16
Release : 43.el7_4.1
Version : 9.1.5
Release : 1.el7
Definitely updated – been using ownCloud for ages.
rpm from CentOS linux distro.
paste the results into https://gist.github.com/ and put the link here.
“No errors have been found.”
“Access denied.”
and other details in a well-sanitized form.
The download json file is empty.
“system”: {
“log_type”: “syslog”,
“datadirectory”: “/var/lib/owncloud/data”,
“updatechecker”: true,
“check_for_working_htaccess”: false,
“asset-pipeline.enabled”: false,
“assetdirectory”: “/var/lib/owncloud”,
“preview_libreoffice_path”: “/usr/bin/libreoffice”,
“apps_paths”: [
“path”: “/usr/share/owncloud/apps”,
“url”: “/apps”,
“writable”: false
“path”: “/var/lib/owncloud/apps”,
“url”: “/apps-appstore”,
“writable”: true
“instanceid”: “REMOVED”,
“dbtype”: “sqlite3”,
“version”: “9.1.5.2”,
“logtimezone”: “UTC”,
“installed”: true,
“theme”: “”,
“loglevel”: 2,
“maintenance”: false,
“integrity.check.disabled”: false
Enabled:
- activity: 2.3.2
- comments: 0.3.0
- configreport: 0.1.1
- dav: 0.2.7
- encryption: 1.3.0
- federatedfilesharing: 0.3.0
- federation: 0.1.0
- files: 1.5.1
- files_pdfviewer: 0.8.1
- files_sharing: 0.10.0
- files_texteditor: 2.1
- files_trashbin: 0.9.0
- files_versions: 1.3.0
- files_videoplayer: 0.9.8
- firstrunwizard: 1.1
- gallery: 15.0.0
- notifications: 0.3.0
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- templateeditor: 0.1
Disabled: - external
- files_antivirus
- files_external
- user_external
- user_ldap
No
Yes
No
Google Chrome
Windows 10
Relevant cut from ssl_access_log:
1.1.1.1 - User [19/Apr/2018:21:26:40 -0700] “PUT /owncloud/remote.php/webdav/Github/ZoneMinder/web/api/.htaccess HTTP/1.1” 507 192
1.1.1.1 - User [19/Apr/2018:21:26:40 -0700] “PUT /owncloud/remote.php/webdav/Github/ZoneMinder/web/api/app/webroot/.htaccess HTTP/1.1” 507 192
1.1.1.1 - User [19/Apr/2018:21:26:40 -0700] “PUT /owncloud/remote.php/webdav/Github/ZoneMinder/web/api/lib/Cake/Console/Templates/skel/webroot/.htaccess HTTP/1.1” 507 192
Empty
Not relevant
