Hello to all. I have an installation of owncloud 10.0.4 that has started throwing this error when creating a user. I tried to update to version 10.0.4 but the error remains the same.
I have another installation of owncloud, same version 10.0.4 which was not causing problems and even after the upgrade to 10.0.10 it is working perfectly.
I have nginx as a webserver and checked of the configurations differ but this is not the case. Seeking some help!
Ok! Thanks. But there should be at least a warning for the user. Currently nothing is displayed and there are errors on console which could mislead a user. I’ve seen also another guy ask the same question.
You’re right, of course. In a perfect world, there would be a warning. OTOH, using a username with only two chars for accessing a cloud platform… but it’s up to you.
