Log into username as created
Access denied
Operating system: ubuntu lts 18.04
Web server: apache2
Database:mariadb
PHP version:7.2
ownCloud version:10.0.10
Client version: Mac
Operating system: Mac
OS language: English
Installation path of client:
logs.
Client logfile: Output of
owncloud --logwindoworowncloud --logfile log.txt
(On Windows usingcmd.exe, you might need to firstcdinto the ownCloud directory)
(See also http://doc.owncloud.org/desktop/2.2/troubleshooting.html#client-logfile ) -
Web server error log:
Hi I have a problem with my owncloud client it won’t log on to the server as such but does with the initial root username it comes up with access denied Ive noticed that whenever I create a user server side it looks ok there but when I look at the backend via terminal and it isn’t created. Does the users folders and credentials be created on first log on from the client side? I’m not sure.
either way it won’t connect to the server by my new created users but does log on sync with the root user of the server itself.
hope you can help
