As admin I can create an account with the username ‘Hexenwaeldchen’, no problem.
But the user can’t login – “username or password wrong”.
‘Hexenwald’ works fine.
I can’t find any hint that the length of usernames is limited to less than 14 characters. So what’s wrong with Hexenwaeldchen?
i think the “Server” category would better fit to this question. If i’m creating a new thread there i’m getting the template below presented. Maybe you could fill out the information asked within it so people are better able to help you?
Thanks for reporting issues back to ownCloud! This is the issue tracker of ownCloud, if you have any support question please check out https://owncloud.org/support
This is the bug tracker for the Server component. Find other components at https://github.com/owncloud/core/blob/master/.github/CONTRIBUTING.md#guidelines
For reporting potential security issues please see https://owncloud.org/security/
To make it possible for us to help you please fill out below information carefully.
Before reporting any issues please make sure that you're using the latest available version for your major branch (e.g. 9.0.x), see https://owncloud.org/changelog/
### Steps to reproduce
1.
2.
3.
### Expected behaviour
### Actual behaviour
### Server configuration
**Operating system**:
**Web server:**
**Database:**
**PHP version:**
**List of activated apps:**
### Client configuration
**Browser:**
**Operating system:**
### Logs
#### Web server error log
#### Browser log
Nothing. It works for me.
But you really should give some more info about your installation.
