I have a user who cannot change their password after requesting a password reset via the forgot password button.
The user gets the email, press the link and it takes them to the URL something like this (Please use the following link to reset your password: https://insdevcloud.icednetworks.info/index.php/lostpassword/reset/form/uu6V6jiqfQub77mESYihA/testuser)
The user type in his new password but nothing happens it just keeps repeating the cycle. and remains on the same page.
Donât know if this can be reproduced but here goes.
- try to login using a wrong password.
- the forgot password link should then appear (âforgot your passwordâ reset it!")
- user received and email with the url link to press
- click the url, take you to the passwords reset page
- user enter new passowrd, presses the "Reset Passwordâ button but nothing happens.
System does not reset password remains on this page.
I am NOT USING LDAP, this is all internal OC users .
Once the new password has been entered, the password should be updated ( provided it meets the password policy standards) in this case it did.
take user to the login screen so they can log in.
Nothing happens remain on the reset password page and does not reset password.
Ubuntu 18.04 lts
Apache 2
Mysql
PHP 7.3.18-1
10.4.1.3
upgrade from 10.0.1
from tar file owncloud-10.4.1.tar.bz2
âsystemâ: {
âpasswordsaltâ: âREMOVED SENSITIVE VALUEâ,
âsecretâ: âREMOVED SENSITIVE VALUEâ,
âtrusted_domainsâ: [
âinsdevcloud.icednetworks.infoâ,
âinsdevcloud.icednetworks.netâ,
âinsdevcloud.icednetworks.comâ,
âinsdevdevcloud.icednetworks.com.auâ,
âinsdevcloudâ,
âx.x.x.193â
âdatadirectoryâ: â/oc/dataâ,
âoverwrite.cli.urlâ: âhttp://localhostâ,
âdbtypeâ: âmysqlâ,
âversionâ: â10.4.1.3â,
âdbnameâ: âocâ,
âdbhostâ: âlocalhostâ,
âdbtableprefixâ: âoc_â,
âmysql.utf8mb4â: true,
âdbuserâ: âREMOVED SENSITIVE VALUEâ,
âdbpasswordâ: âREMOVED SENSITIVE VALUEâ,
âlogtimezoneâ: âAustralia/Melbourneâ,
âapps_pathsâ: [
âpathâ: â/var/www/owncloud/appsâ,
âurlâ: â/appsâ,
âwritableâ: false
âpathâ: â/var/www/owncloud/apps-externalâ,
âurlâ: â/apps-externalâ,
âwritableâ: true
âpathâ: â/var/www/owncloud/insappsâ,
âurlâ: â/insappsâ,
âwritableâ: true
âinstalledâ: true,
âmaintenanceâ: false,
âlog_rotate_sizeâ: 10485760,
âenable_avatarsâ: true,
âallow_user_to_change_display_nameâ: true,
âthemeâ: ââ,
âmail_smtpmodeâ: âsmtpâ,
âmail_from_addressâ: âREMOVED SENSITIVE VALUEâ,
âmail_domainâ: âREMOVED SENSITIVE VALUEâ,
âmail_smtphostâ: âREMOVED SENSITIVE VALUEâ,
âlog_typeâ: âowncloudâ,
âlogfileâ: âowncloud.logâ,
âloglevelâ: 1,
âlogdateformatâ: âY-m-d H:i:sâ,
âtrashbin_retention_obligationâ: âdisabledâ,
âupdatecheckerâ: true,
âfiles_external_allow_create_new_localâ: âtrueâ,
âintegrity.check.disabledâ: false,
âmail_smtpportâ: â25â,
âintegrity.ignore.missing.app.signatureâ: [
âins-themeâ,
âins_testâ
âmemcache.localâ: â\OC\Memcache\Redisâ,
âmemcache.distributedâ: â\OC\Memcache\Redisâ,
âmemcache.lockingâ: â\OC\Memcache\Redisâ,
âredisâ: {
âhostâ: âlocalhostâ,
âportâ: 6379
âtoken_auth_enforcedâ: true,
âdebugâ: false,
âknowledgebaseenabledâ: true,
âremember_login_cookie_lifetimeâ: 2592000,
âinstanceidâ: âocv11meksi5iâ
Enabled:
- activity: 2.5.3
- afterlogic: 1.2.2
- announcementcenter: 1.2.1
- bookmarks: 0.10.6
- brute_force_protection: 1.0.1
- calendar: 1.6.4
- camerarawpreviews: 0.6.4
- checksum: 0.3.5
- comments: 0.3.0
- configreport: 0.2.0
- contacts: 1.5.5
- customgroups: 0.6.0
- dav: 0.5.0
- diagnostics: 0.1.4
- external: 1.4.0
- extract: 1.2.4
- federatedfilesharing: 0.5.0
- federation: 0.1.0
- files: 1.5.2
- files_antivirus: 0.15.1
- files_external: 0.7.1
- files_mediaviewer: 1.0.2
- files_pdfviewer: 0.11.1
- files_sharing: 0.12.0
- files_texteditor: 2.3.0
- files_textviewer: 1.0.3
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- firstrunwizard: 1.2.0
- gallery: 16.1.1
- guests: 0.9.0
- impersonate: 0.5.0
- ins-theme: 2.3.1
- market: 0.5.0
- nextbackup: 19.12.1
- notes: 2.0.6
- notifications: 0.5.0
- oauth2: 0.4.3
- onlyoffice: 4.2.1
- passman: 2.1.4
- password_policy: 2.1.2
- provisioning_api: 0.5.0
- qownnotesapi: 19.1.0
- systemtags: 0.3.0
- tasks: 0.9.7
- templateeditor: 0.4.0
- twofactor_totp: 0.6.1
- updatenotification: 0.2.1
- user_external: 0.6.0
Disabled: - encryption
- theme-example-master
Are you using external storage, if yes which one: local/smb/sftp/âŚ
No internal
No
Are you using an external user-backend, if yes which one: LDAP/ActiveDirectory/Webdav/âŚ
No
None - not using LDAP
Chrome/ms Edge/ Firefox
windows 10
insdevcloud.icednetworks.info-error.log
[Tue Jun 23 06:25:36.112736 2020] [ssl:warn] [pid 25707] AH01909: insdevcloud.icednetworks.info:443:0 server certificate does NOT include an ID which matches the server name
[Tue Jun 23 09:37:27.395024 2020] [php7:warn] [pid 29972] [client 192.168.168.104:54002] PHP Warning: "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /usr/share/phpmyadmin/libraries/config/Form
Display.php on line 660
[Tue Jun 23 18:49:37.252322 2020] [ssl:warn] [pid 2032] AH01909: insdevcloud.icednetworks.info:443:0 server certificate does NOT include an ID which matches the server name
[Tue Jun 23 18:49:37.320405 2020] [ssl:warn] [pid 2038] AH01909: insdevcloud.icednetworks.info:443:0 server certificate does NOT include an ID which matches the server name
root@insdevcloud:/var/www/owncloud# tail -f owncloud.log
{âreqIdâ:âXvHEtFf6KDMsGNlOLkJuDwAAAAkâ,âlevelâ:3,âtimeâ:â2020-06-23 19:00:36â,âremoteAddrâ:â192.168.168.202â,âuserâ:"â",âappâ:âPHPâ,âmethodâ:âGETâ,âurlâ:"/index.php/login",âmessageâ:âUndefined index: username at /var/www/owncloud/insapps/ins-theme/core/templates/login.php#59â}
{âreqIdâ:âXvHExLW-gv-BZplu2ADMfQAAAAIâ,âlevelâ:3,âtimeâ:â2020-06-23 19:00:52â,âremoteAddrâ:â192.168.168.202â,âuserâ:"â",âappâ:âPHPâ,âmethodâ:âGETâ,âurlâ:"/index.php/login?redirect_url=%252Findex.php%252Fsettings%252Fadmin%253Fsectionid%253Dgeneral",âmessageâ:âUndefined index: username at /var/www/owncloud/insapps/ins-theme/core/templates/login.php#59â}
{âreqIdâ:âXvHE5@FdQWPB3OXlm4wtTQAAAAcâ,âlevelâ:3,âtimeâ:â2020-06-23 19:01:28â,âremoteAddrâ:â192.168.168.202â,âuserâ:"â",âappâ:âPHPâ,âmethodâ:âGETâ,âurlâ:"/index.php/login",âmessageâ:âUndefined index: username at /var/www/owncloud/insapps/ins-theme/core/templates/login.php#59â}
{âreqIdâ:âXvHE8RKYjWqkclsONfkKVgAAAAAâ,âlevelâ:2,âtimeâ:â2020-06-23 19:01:37â,âremoteAddrâ:â192.168.168.202â,âuserâ:"â",âappâ:âcoreâ,âmethodâ:âPOSTâ,âurlâ:"/index.php/login",âmessageâ:âLogin failed: âtestuserâ (Remote IP: â192.168.168.202â)â}
{âreqIdâ:âXvHE8RKYjWqkclsONfkKVwAAAAAâ,âlevelâ:3,âtimeâ:â2020-06-23 19:01:37â,âremoteAddrâ:â192.168.168.202â,âuserâ:"â",âappâ:âPHPâ,âmethodâ:âGETâ,âurlâ:"/index.php/login?user=testuser",âmessageâ:âUndefined index: username at /var/www/owncloud/insapps/ins-theme/core/templates/login.php#59â}
{âreqIdâ:âXvHFLHowV5g0c0aGu2-erwAAAAsâ,âlevelâ:3,âtimeâ:â2020-06-23 19:02:36â,âremoteAddrâ:â192.168.168.202â,âuserâ:"â",âappâ:âPHPâ,âmethodâ:âGETâ,âurlâ:"/index.php/login",âmessageâ:âUndefined index: username at /var/www/owncloud/insapps/ins-theme/core/templates/login.php#59â}
