Hello everyone
I had a problem migrating from Sqllite to MySQL.
After the job done I don’t see any user in the ’ anyone ’ link but if I do clik on any other group I can see them.
Can solve this?
Thank you.
if i’m creating a new thread in the better fitting “Server” category (AFAIK the previously used Development category has the purpose to discuss topics around doing Development on ownCloud and not about issue with ownCloud) i’m getting the template below presented. Maybe you could fill out the information asked within it so people are better able to help you with your issue?
This could also include the steps you have chosen to migrate from Sqlite to MySQL.
Thanks for reporting issues back to ownCloud! This is the issue tracker of ownCloud, if you have any support question please check out https://owncloud.org/support
This is the bug tracker for the Server component. Find other components at https://github.com/owncloud/core/blob/master/.github/CONTRIBUTING.md#guidelines
For reporting potential security issues please see https://owncloud.org/security/
To make it possible for us to help you please fill out below information carefully.
Before reporting any issues please make sure that you're using the latest available version for your major branch (e.g. 9.0.x), see https://owncloud.org/changelog/
### Steps to reproduce
1.
2.
3.
### Expected behaviour
### Actual behaviour
### Server configuration
**Operating system**:
**Web server:**
**Database:**
**PHP version:**
**List of activated apps:**
### Client configuration
**Browser:**
**Operating system:**
### Logs
#### Web server error log
#### Browser log
Hi Mario,
Did you find the issue ? After upgrade I ‘lost’ my users on 2 different instances of owncloud
Stefaan
Hello StefaanH,
Did you find the issue? I’m having a similar problem after migrating & upgrading our instance. No users are shown, not even after I create a new one. All users are able to login however.
Thanks!
Nick
