- Log in to your owncloud install via web with admin user.
- Access the users tab (index.php/settings/users)
- Wait for the load time to be epic and long.
The users table should load within a few seconds.
The users table shouldn’t take that long to load, I’m using regular users through database and nothing fancy like LDAP etc… and it takes ages to load I don’t even have 100 users and I would expect this to be faster as it makes it painfully long to add a new user or even manage the actual users.
Operating system: Ubuntu 18.04 LTS
Web server: Apache 2
PHP version: 7.2
10.1.0.4
Fresh install
Ubuntu repository
(no clue what signing status is or where to get)
“system”: {
“updatechecker”: false,
“instanceid”: “oc9z25lemgxh”,
“trusted_domains”: [
“34.94.237.125”,
“cloud.mitu.pw”
“datadirectory”: “/mnt/cloud-mitu/cloud-data”,
“overwrite.cli.url”: “http://34.94.237.125”,
“dbtype”: “mysql”,
“version”: “10.1.0.4”,
“dbname”: “the-last-hope”,
“dbhost”: “130.211.207.85”,
“dbtableprefix”: “oc_”,
“logtimezone”: “UTC”,
“installed”: true,
“maintenance”: false,
“skeletondirectory”: “”,
“files_external_allow_create_new_local”: true,
“log_type”: “owncloud”,
“logfile”: “owncloud.log”,
“loglevel”: “3”,
“mail_smtpmode”: “smtp”,
“mail_smtpauthtype”: “LOGIN”,
“mail_smtpauth”: 1,
“mail_smtpport”: “587”,
“mail_smtpname”: “REMOVED SENSITIVE VALUE”,
“mail_smtppassword”: “REMOVED SENSITIVE VALUE”,
“mail_smtpsecure”: “tls”,
“integrity.ignore.missing.app.signature”: [
“theme-mitu”
“memcache.local”: “\OC\Memcache\Redis”,
“redis”: {
“host”: “10.168.0.5”,
“port”: 6379,
“password”: “REMOVED SENSITIVE VALUE”
“memcache.locking”: “\OC\Memcache\Redis”,
“filelocking.enabled”: true
Enabled:
- comments: 0.3.0
- configreport: 0.1.1
- dav: 0.4.0
- federatedfilesharing: 0.3.1
- federation: 0.1.0
- files: 1.5.1
- files_external: 0.7.1
- files_sharing: 0.11.0
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- firstrunwizard: 1.1
- market: 0.3.0
- notifications: 0.4.1
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- theme-mitu: 1.0.0
- updatenotification: 0.2.1
Disabled: - encryption
- external
- files_videoplayer
- user_external
Yes, I have logs into the data folder and the rest of the accounts for users etc I use “gcsfuse” to mount a Google Storage Bucket to use as “main storage” since it only supports Amazon S3.
Are you using encryption:
no
No
Google Chrome
Mac OS High Sierra
cat data/owncloud.log
{"reqId":"jJc2yyLpsHIfsSWgrkEc","level":3,"time":"2019-06-22T18:08:15+00:00","remoteAddr":"187.254.104.115","user":"--","app":"no app in context","method":"POST","url":"\/index.php","message":"User backend OC\\User\\Database is returning home: \/var\/www\/owncloud\/data\/admin for user: admin which differs from existing value: "}
{"reqId":"E0SHcLBhGYFsAlLH4Wza","level":2,"time":"2019-06-22T19:03:18+00:00","remoteAddr":"80.14.152.87","user":"--","app":"core","method":"GET","url":"\/","message":"Trusted domain error. \"80.14.152.87\" tried to access using \"mitu-cloud-testing.c.pepino-mitu-moto.internal\" as host."}
js.js?v=a63c8881a74e…98529f837e9a58:1088 Missing argument $row in OC.Notification.hide() call, caller needs to be adjusted to only dismiss its own notification
hide @ js.js?v=a63c8881a74e…98529f837e9a58:1088
initDeleteHandling @ users.js?v=a63c8881a…e98529f837e9a58:370
(anonymous) @ users.js?v=a63c8881a…e98529f837e9a58:701
j @ jquery.js:3099
fireWith @ jquery.js:3211
ready @ jquery.js:3417
I @ jquery.js:3433
I actually get a good response back but takes at least 3-5 min to load
