Using ownCloud with external file transfers
Hi!
I would like to know if ownCloud allows, such as I think that I have read, force rescan, via crontab, of data directories and automatically, create the entries in the system when, for example, one use transfer a file using scp or ftp. In this case his home could be the same that the ownCloud target.
One of my goals using this tool is to get have a service that allows store files via web interface and WebDAV and also, transfer backups from other machines via FTP or SCP to user storage.
I hope your answers.
Thanks in advance.
Regards,
Antonio.
ownCloud doesn’t support transferring files via FTP or SCP. The two supported methods are:
WebGUI
WebDAV
However you can mount external storages like FTP or SCP into ownCloud via the “External Storage Support App” (see doc.owncloud.org). Some other possibilities are explained here:
Thanks for your answer. I’m going to consider this option.
Regards,
Antonio
