I use about 9 different files while on a time-limited coffee shop WiFi hot spot. I expect the files to sync when on WiFi or wait for the the network connection to sync.
After the 1 hour of free WiFi, my Windows 10 notebook loses network connection, despite still having WiFi connection. When I return to a home network, these 9 files do not sync anymore. The are various errors from “downloaded file does not match the checksum” to “server version downloaded, local copy renamed”.
I have to rename the files while connected to my home network to get them to sync again. The files are not corrupted as far as I can tell, but ownCloud stops trying to sync them.
This seems to happen on timed connections and on poor connections, like a train (20 minutes connection, then 10 minutes none).
- Go to coffee shop with time limited WiFi hotspot
- Open and save files, both while connected to internet and after the 1 hour has expired
- Files used no longer sync. Files have to be renamed while connected to local network to get syncing to work again.
Web server: university provided ownCloud
ownCloud version:
Client version: 2.4.0 build 8894
Operating system: Windows 10
OS language: English
Installation path of client:
I guess that I will need to log it the next time I am at the coffee shop.
