Using WHM or Cpanel to backup to owncloud destination
I’m afraid I may not know enough to ask this intelligently but,
I have access to WHM (running CentOS 6) and Cpanel. My goal is to configure a remote backup to a large 1TB owncloud destination. My first attempt was to use the Webdav component of WHM Backup configuration, but I’ve discovered my the Webdav method to access my owncloud destination has a maximum 4GB file limit and my backup is between 10GB and 30GB, thus the transfer fails.
If I run through the CentOS desktop application installation should there be a GUI interface I can use after its installed?
  • List item
If so how/where do I find this?
  • List item
If not, and I need to configure this via command line, what are the commands to set the destination and a time sync?
Thanks in advance
You don’t have the resources to do larger uploads? Did you try the tips here: ownCloud Documentation Overview
Closing due to the lack of feedback / info.
