Hello there!
Is there a way to have a videoplayer intigration within the owncloud site. Ive read that there was an app for it but i don’t think there is one now.
Hello there!
I think, it’s included.
Hello alfredb,
I installed the videoplayer in my owncloud. it works fine ! thanks for that.
but now i get an warning in the settings menu. do you know how i can disable the warning ? (There were problems with the code integrity check)
the core error is because i changed the background of the login page and the videoplayer is missing its signature. can’t find any info on how to deal with this.
thanks for your help!
Did you install it from github?
Videoplayer is contained in the normal oC install packages, of course with a signature. You should use that version, then the signature warning goes away.
Maybe my fault, the link I posted was for information. Sorry for that.
Regarding core/img/background.jpg: This file doesn’t match your installation, it’s probably from another version. You should extract the suitable file from the original install package.
No really, there was a way if am not wrong, will let you know in mins after asking from my wife, she was working on the same.
With Regards,
Ralto
