When user share a photo and share as a link in owncloud, they click on the shared address and then the image is small and it has to be downloaded. Once you have entered the shared address that I need, the photo is displayed directly, so you don’t have to download it.
Hi, can you please fill out the issue template?
it makes it far easier for others to help you solve your problem.
Can you give us the following infos:
Thanks for reporting issues back to ownCloud! This is the issue tracker of ownCloud, if you have any support question please check out https://owncloud.org/support
This is the bug tracker for the Server component. Find other components at https://github.com/owncloud/core/blob/master/.github/CONTRIBUTING.md#guidelines
For reporting potential security issues please see https://owncloud.org/security/
To make it possible for us to help you please fill out below information carefully.
Before reporting any issues please make sure that you're using the latest available version for your major branch (e.g. 9.0.x), see https://owncloud.org/changelog/
### Steps to reproduce
1.
2.
3.
### Expected behaviour
### Actual behaviour
### Server configuration
**Operating system**:
**Web server:**
**Database:**
**PHP version:**
**List of activated apps:**
### Client configuration
**Browser:**
**Operating system:**
### Logs
#### Web server error log
#### Browser log
just copy & paste this to your next reply, remove the backslashes (\), and substitute the necessary information.
Operating system Ubuntu 18.04.1 LTS
ownCloud version 10.0.10
If this implies a question, the answer is: Yes, that’s the way it works.
My main question is this, how can I see the photo directly from the public link without download
AKAIK you’ll get only a downscaled preview first.
I can see preview, but the photo small and it must need download. We need to show original photo size before download, is it possible?
I assume it’s not possible, with currently available resources.
