I’m running OC 10.4.1. Are there any reporting tools for usage by user or group?
I saw that I can impersonate a user and look at their General screen. That shows some approximation like 'You are using 16.7 GB of 100 GB (16.69 %) '. However, It will get very tedious to do this with any real number of user.
I’m open to coding an external report to run via cron. Maybe someone can point me in the right direction of what API call is creating the ‘You are using 16.7 GB of 100 GB (16.69 %)’ part.
I second that idea, it would be great to have an extra line in the users admin panel to show the real usage.
You can go with some telegraf/infuxdb/grafana to get these values, but it’s a bit tricky.
Cheers.
I’d suggest you use telegraf/influxdb/grafana with this module.
You’ll have realtime and browsable data you could even set alerting as you wanted.
I prefer this solution in my case since it has more pros than cons. Having the data browsable being possible mostly directly while your script would be a bit more of an hassle.
