Visualization question
where is your question?
I am sorry
I have a
Currently viewing images just uploaded to my own cloud.
when I select one I get the dialog box asking me if I want to open the image or save it
I have checked settings in firefox and there is no reason why images should be blocked, or I dont see
Also I do not see the the gallery layout button (top right) in order to view files as thumbs instead of list.
Thank you for any information on that
Do you have the Gallery App enabled? If not, go to Market or Apps in the top left corner and install the Gallery App. Then you will be able to view Images in ownCloud instead of having to download them to your computer.
I Ok I just saw that
i get
No marketplace connection
when i click on install
Ok sorry I tried again and it worked
thanks !
Yay :slight_smile:
Glad it worked
Yes super neat thanks !
I have an question on the same topic if I may.
I can not find where to modify the login page, change url ico file, Logo, metas etc
Is there a plug in for this too
Philip
Sounds to me like you would like another theme for your ownCloud
We have a lot of information on how to use ownCloud documented in our great documentation
Here is the section about themes
Hi thanks for that, I had a look but this is for entreprise edition only ?
I just need to change the logo and home page image, slogan / title etc
I was using nextcloud before and these functions were integrated in the admin…?
thanks
Philip
Seems you can do the same in the community edition: ownCloud Documentation Overview
At some point in time it looks that its even possible to install themes from the appstore: Marketplace
Hi Thanks for your answer Its not exactly what I am looking for not having the time or nowhow to build a theme from scratch
I do not see any other theme in there apart from enterprise edition
I was using next cloud before switching to owncloud because of the desktop synch app not working properly on my Debian set up, in next cloud you can change logo meta title colors background images etc directly in the admin…
How come its not posible here ?
Philip
I think it’s only possible if you have the enterprise version. In the way that you described.
If I understood you correctly you want to do something like just upload a picture in your admin section and that should be the background image, right?
https://owncloud.com/wp-content/uploads/2015/07/Use-Cases-ownBrander-V06.pdf
Is that what you imagined? If yes - than it’s only available in that form for the enterprise customers.
But I did some googeling and found a guide that explains how you could modify the standard theme and get what you want:
I don’t know if you can speak German, but I suppose you could find a guide in English too.
Do this help you?
Thanks for that no I can do French or English but not German.
I can do quite a bit of own branding by replacing the images in /core/img
seems to work ok
I am glad that things work for you :slight_smile:
