Hi everyone,
I’ve installed Owncloud 10 on a raspberry (Raspbian) and I managed to remove all warning message in admin parameter page but one message that is something like “We recommend you to enable the system planned task”.
As I did not find any doc page talking about this message, I’ve put a message to github/doc to ask the developers to talk about this. They proposed me to do what was written in this page which talks about enabling the cron.php.
I’ve done what was asked with
crontab -u www-data -e
*/15 * * * * /usr/bin/php -f /path/to/your/owncloud/cron.php
But the warning is still here and if I test the following command
su -s /bin/bash -c '/usr/bin/php -f /var/www/owncloud/cron.php' www-data
it gives me
PHP Fatal error: Uncaught Doctrine\DBAL\DBALException: Failed to connect to the database: An exception occured in driver: could not find driver in /var/www/owncloud/lib/private/DB/Connection.php:63
Stack trace:
#0 /var/www/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(429): OC\DB\Connection->connect()
#1 /var/www/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(389): Doctrine\DBAL\Connection->getDatabasePlatformVersion()
#2 /var/www/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(328): Doctrine\DBAL\Connection->detectDatabasePlatform()
#3 /var/www/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(623): Doctrine\DBAL\Connection->getDatabasePlatform()
#4 /var/www/owncloud/lib/private/DB/Connection.php(146): Doctrine\DBAL\Connection->setTransactionIsolation(2)
#5 /var/www/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(172): OC\DB\Connection->__construct(Array, Object(Doctrine\DBAL\Driver\PDOMySql\Driver), Object(Doctrine\D in /var/www/owncloud/lib/private/DB/Connection.php on line 63
Stack trace:
Could someone tell me what’s wrong ?
Thanks !
