Web Interface Max File Size Upload
  1. Log into oC Server, select admin
  2. Change “File Handling, Maximum upload size” to anything other than the default “2 MB”
oC will allow files larger than 2 MB to be uploaded via the web interface
Maximum upload size setting keeps reverting to 2 MB - unable to upload larger files
Operating system: Ubuntu 16.04.2 x86_64
Web server: Apache
PHP version: 7.0
Updated from an older ownCloud or fresh install: 9.1.3
Special configuration (external storage, external authentication, reverse proxy, server-side-encryption): No encryption or add-ons installed. External storage for Dropbox and Google are enabled.
[Tue Feb 21 06:25:05.477217 2017] [mpm_prefork:notice] [pid 978] AH00163: Apache/2.4.18 (Ubuntu) OpenSSL/1.0.2g configured -- resuming normal operations
[Tue Feb 21 06:25:05.477249 2017] [core:notice] [pid 978] AH00094: Command line: '/usr/sbin/apache2'
Integrity status for oC9+
Documentation how to raise this upload limit in your webservers configuration is available at [1].
[1] ownCloud Documentation Overview
That worked! I had to change it in php.ini.
Thanks!
