- Install owncloud server on unraid
- Install OAuth2 app
- Install 2FA and activate
- Try to login on web = ok
- Try to login on desktop client - 403 forbidden
It should prompt me to grant access from desktop client request on browser and do 2FA then automatically go back to desktop client
403 forbidden error
unraid
I don’t know. sorry I’m noob. Is it nginx?
mariaDB
10.9.1.2
fresh install
unraid community apps (dlandon’s Repository)
I don’t know what’s this?
It says “No errors have been found.”
2FA, OAuth2
Local
No
No
Chrome
Win 11
owncloud.log (502.6 KB)
Trobuleshooting:
I tried to research and edit .htaccess on owncloud and set
`SetEnvIf Authorization "(.*)" HTTP_AUTHORIZATION=$1`
Restarted owncloud docker but no avail. Still 403 forbidden error.
