1.Go to main login page (domain.com/owncloud)
2.Try to login using valid credentials
3. (login works within network (192.168.1.x) but not outside the network (mydomain.com/owncloud))
Should have logged in
After submission, login screen reappears with no error messages
Linux - ClearOS
Apache
MySql
Can't get to admin page either - unable to find password using defaults
fresh
ClearCenter
<?php
$CONFIG = array (
'log_type' => 'syslog',
'datadirectory' => '/usr/clearos/EXTRA-DRIVE/data/',
'updatechecker' => false,
'check_for_working_htaccess' => false,
'asset-pipeline.enabled' => false,
'assetdirectory' => '/var/lib/owncloud',
'preview_libreoffice_path' => '/usr/bin/libreoffice',
'apps_paths' =>
array (
0 =>
array (
'path' => '/usr/share/owncloud/apps',
'url' => '/apps',
'writable' => false,
1 =>
array (
'path' => '/var/lib/owncloud/apps',
'url' => '/apps-appstore',
'writable' => true,
'dbtype' => 'mysql',
'dbname' => 'owncloud',
'dbuser' => 'owncloud',
'dbpassword' => 'KNdloxxxxxIOIBo',
'dbhost' => '127.0.0.1:3308',
'dbtableprefix' => 'oc_',
'instanceid' => 'oc5nz65ow31g',
'passwordsalt' => 'ZIpCsmUCvBxxxdZ84aUAYA75KVL',
'secret' => 'rqgpqDA480d0YBJtpgfOxxxKGVgdbgKghXn2ZUj6Yj',
'trusted_domains' =>
array (
0 => 'xxxx',
1 => '6xxx6',
2 => '10.50.100.1',
3 => 'globaXXXXte.com',
4 => '',
'overwrite.cli.url' => 'http://localhost/owncloud',
'version' => '8.2.4.2',
'logtimezone' => 'UTC',
'installed' => true,
'ldapIgnoreNamingRules' => false,
Are you using external storage, if yes which one: local/smb/sftp/...
no
Are you using an external user-backend, if yes which one: LDAP/ActiveDirectory/Webdav/...
LDAP
