Webcron Error 404
1.Login to Easycron
2.Create a cron job with https://mydomain.net/var/www/owncloud/cron.php
3.Test cronjob
Thr Cronjob should start
Error 404 - File not found
(I can’t open the file in the Browser too)
Operating system: Raspbian Jessie
Web server: Nginx
Database: sqlite3(?)
PHP version: Idk
ownCloud version (see ownCloud admin page): 9.0.4 (stable)
ownCloud log (data/owncloud.log, see How to find webserver or OC logfile / enable php logfile): Can’t find it
Special configuration (external storage, external authentication, reverse proxy, server-side-encryption): No
Integrity status for oC9+
paste the results here.
Integrity checker has been disabled. Integrity cannot be verified.
where did you get this path from? This looks quite wrong as you can see in the example here:
A correct path would be:
https://mydomain.net/owncloud/cron.php
or:
https://mydomain.net/cron.php
depending how you access your installation.
[quote=“RealRancor, post:2, topic:2341”]
[/quote]didn’t work either.
[/quote] works now. Thank you :slight_smile:
