Webdav can't get on folder level
  1. Try to get command with webdav on folder level
  2. you get 200 response which means OK
  3. Indeed no folder has been synced
I should get the folder synced if have got perms to that
Get 200 response and nothing happened
Operating system: Ubuntu 16.04.4 LTS
Web server: Apache/2.4.18 (Ubuntu
Database: mysql Ver 14.14 Distrib 5.7.24
PHP version: PHP 7.0.32-0ubuntu0.16.04.1
ownCloud version: (see ownCloud admin page) 10.0.10.4
Updated from an older ownCloud or fresh install: previous
Where did you install ownCloud from: repo
Enabled:
  • activity: 2.4.1
  • comments: 0.3.0
  • configreport: 0.1.1
  • customgroups: 0.4.0
  • dav: 0.4.0
  • federatedfilesharing: 0.3.1
  • federation: 0.1.0
  • files: 1.5.1
  • files_external: 0.7.1
  • files_pdfviewer: 0.10.0
  • files_sharing: 0.11.0
  • files_trashbin: 0.9.1
  • files_versions: 1.3.0
  • firstrunwizard: 1.1
  • gallery: 16.1.1
  • guests: 0.7.0
  • market: 0.3.0
  • notifications: 0.3.5
  • password_policy: 2.0.2
  • provisioning_api: 0.5.0
  • security: 0.0.2
  • systemtags: 0.3.0
  • updatenotification: 0.2.1
  • user_ldap: 0.13.0
    Disabled:
  • encryption
  • external
  • files_videoplayer
  • user_external
  • xmas
no
no
webdav
can’t provide
I don’t understand you problem. Could you explain more in detail?
Sure! For me it’s also strange behavior I could see.
We have CRM software that uses offline sync with sync based on files. Those files are placed on owncloud folder via owc client. The problem is that CRM client tries to use GET method to get list of files in folder and receives 200 but no list is returned.
Maybe screen below will explain it more:
Any idea how to get it working?
Hi Alfred,
Any comments to my response?
Thanks,
Yes , sorry for the delay.
As you can see at the right side of your pic, the client you are using doesn’t use WebDAV protocol. But this is a must for communicating with ownCloud.
