- Upgrade to 9.1.2 from 9.1.0
Things should continue working
Your web server is not yet set up properly to allow file synchronization because the WebDAV interface seems to be broken.
Operating system: Ubuntu Xenial (16.04 LTS)
Web server: nginx
Database: MySQL 5.7
PHP version: PHP 5.6
ownCloud version (see ownCloud admin page): 9.1.2
Updated from an older ownCloud or fresh install: Update
Empty!
No PHP Errors
Integrity status for oC9+
I’ve been troubleshooting this since yesterday, updated nginx to the latest version, updated PHP to the latest version, no change. There is no errors anywhere to be found.
PROPOUND returns 200
74.69.82.206 - admin [29/Nov/2016:12:42:00 -0500] “PROPFIND /remote.php/webdav/ HTTP/1.1” 200 386 “-” “Mozilla/5.0 (Macintosh) mirall/2.2.4 (build 3709)”
This is the result of PROPFIND in the browser:
<?xml version="1.0"?>
<d:multistatus xmlns:d="DAV:" xmlns:s="http://sabredav.org/ns" xmlns:oc="http://owncloud.org/ns">
<d:response>
<d:href>/remote.php/webdav/</d:href>
<d:propstat>
<d:prop>
<d:getlastmodified>Mon, 28 Nov 2016 20:41:17 GMT</d:getlastmodified>
<d:getetag>"583c966e0057c"</d:getetag>
<d:resourcetype>
<d:collection/>
</d:resourcetype>
<oc:fileid>2</oc:fileid>
<oc:permissions>RDNVCK</oc:permissions>
<oc:size>1377307263</oc:size>
<oc:tags/>
<oc:favorite></oc:favorite>
<oc:comments-unread>0</oc:comments-unread>
<oc:owner-display-name>admin</oc:owner-display-name>
<oc:share-types/>
</d:prop>
<d:status>HTTP/1.1 200 OK</d:status>
</d:propstat>
<d:propstat>
<d:prop>
<d:getcontenttype/>
<d:getcontentlength/>
</d:prop>
<d:status>HTTP/1.1 404 Not Found</d:status>
</d:propstat>
</d:response>
<d:response>
<d:href>/remote.php/webdav/DigitalHDA/</d:href>
<d:propstat>
<d:prop>
<d:resourcetype>
<d:collection/>
</d:resourcetype>
<oc:fileid>40</oc:fileid>
<oc:size>1372553049</oc:size>
<oc:tags/>
<oc:share-types/>
</d:prop>
</d:propstat>
<d:propstat>
<d:prop>
<d:getcontenttype/>
</d:prop>
</d:propstat>
</d:response>
<d:response>
<d:href>/remote.php/webdav/Documents/</d:href>
<d:propstat>
<d:prop>
<d:getlastmodified>Mon, 24 Oct 2016 16:44:21 GMT</d:getlastmodified>
<d:getetag>"580e3a65b7116"</d:getetag>
<d:resourcetype>
<d:collection/>
</d:resourcetype>
<oc:fileid>3</oc:fileid>
<oc:size>36227</oc:size>
<oc:tags/>
<oc:share-types/>
</d:prop>
</d:propstat>
<d:propstat>
<d:prop>
<d:getcontenttype/>
</d:prop>
</d:propstat>
</d:response>
<d:response>
<d:href>/remote.php/webdav/Photos/</d:href>
<d:propstat>
<d:prop>
<d:getlastmodified>Mon, 24 Oct 2016 16:44:22 GMT</d:getlastmodified>
<d:getetag>"580e3a662527b"</d:getetag>
<d:resourcetype>
<d:collection/>
</d:resourcetype>
<oc:fileid>5</oc:fileid>
<oc:size>678556</oc:size>
<oc:tags/>
<oc:share-types/>
</d:prop>
</d:propstat>
<d:propstat>
<d:prop>
<d:getcontenttype/>
</d:prop>
</d:propstat>
</d:response>
<d:response>
<d:href>/remote.php/webdav/ownCloud%20Manual.pdf</d:href>
<d:propstat>
<d:prop>
<d:getetag>"90b7d244ab044565a7c47d6d9c43c916"</d:getetag>
<d:getcontenttype>application/pdf</d:getcontenttype>
<d:resourcetype/>
<oc:fileid>9</oc:fileid>
<oc:permissions>RDNVW</oc:permissions>
<d:getcontentlength>4039431</d:getcontentlength>
<oc:tags/>
<oc:share-types/>
</d:prop>
</d:propstat>
<d:propstat>
<d:prop>
<oc:size/>
</d:prop>
</d:propstat>
</d:response>
</d:multistatus>
Which seems to indicate everything is okay? Except for the 404’s, but I think that’s normal too.
Using curl with a wrong username/password:
<?xml version="1.0" encoding="utf-8"?>
<d:error xmlns:d="DAV:" xmlns:s="http://sabredav.org/ns">
<s:exception>Sabre\DAV\Exception\NotAuthenticated</s:exception>
<s:message>Username or password was incorrect</s:message>
</d:error>
Using the right password with Curl:
curl --request PROPFIND --user admin:EReS2fah9gaesaec --header "Content-Type: text/xml" --header "Brief:t" --data "<D:propfind xmlns:D='DAV:'><D:prop><D:displayname/></D:prop></D:propfind>" https://cloud.digitalhda.com/remote.php/webdav/
<d:response>
<d:propstat>
<d:prop/>
<d:status>HTTP/1.1 418 I'm a teapot</d:status>
</d:propstat>
</d:response>
<d:response>
<d:propstat>
<d:prop/>
</d:propstat>
</d:response>
<d:response>
<d:propstat>
<d:prop/>
</d:propstat>
</d:response>
<d:response>
<d:propstat>
<d:prop/>
</d:propstat>
</d:response>
<d:response>
<d:propstat>
<d:prop/>
</d:propstat>
</d:response>
</d:multistatus>
So it SEEMS the WebDav server is working, it lists the contents of my root folder yet no client wants to connect. The own cloud client says “invalid response to an authenticated webdav request”
