WebUI doesn't load correctly
  1. Updated OwnCloud
  2. Update failed: restored to older version
  3. Restarted Docker Container
  4. WebUI doesn’t load correctly
Owncloud should load correctly and I can access the WebUI
Everything except the WebUI works, but the WebUI shows only this:
I can’t set, view or change anything from there
unRaid 6.9.2 with docker
nginx
MariaDB 10.3.34
10.8.0.4
Updated from 10.8 to 10.9, update failed, restored to 10.8
Docker Hub
    "system": {
        "filelocking.enabled": true,
        "redis": {
            "host": "\/var\/run\/redis\/redis-server.sock",
            "port": 0,
            "timeout": 0
        "instanceid": "oci9p6dbi3d6",
        "trusted_domains": [
            "192.168.1.201",
            "mydomain.tld"
        "datadirectory": "\/data",
        "overwrite.cli.url": "https:\/\/mydomain.tld\/",
        "overwritehost": "mydomain.tld",
        "overwriteprotocol": "https",
        "dbtype": "mysql",
        "version": "10.8.0.4",
        "dbname": "owncloud",
        "dbhost": "localhost",
        "trusted_proxies": [
            "swag"
        "dbtableprefix": "oc_",
        "mysql.utf8mb4": true,
        "logtimezone": "UTC",
        "apps_paths": [
                "path": "\/config\/www\/owncloud\/apps",
                "url": "\/apps",
                "writable": false
                "path": "\/config\/www\/owncloud\/apps-external",
                "url": "\/apps-external",
                "writable": true
        "installed": true,
        "mail_smtpmode": "smtp",
        "mail_smtpsecure": "tls",
        "mail_smtpauthtype": "LOGIN",
        "mail_smtpauth": 1,
        "mail_smtpport": "587",
        "files_external_allow_create_new_local": "true",
        "updater.secret": "***REMOVED SENSITIVE VALUE***",
        "theme": "",
        "loglevel": 2,
        "maintenance": false,
        "allow_user_to_change_mail_address": ""
Enabled:
  - comments:
    - Version: 0.3.0
    - Path: /config/www/owncloud/apps/comments
  - configreport:
    - Version: 0.2.0
    - Path: /config/www/owncloud/apps/configreport
  - dav:
    - Version: 0.7.0
    - Path: /config/www/owncloud/apps/dav
  - federatedfilesharing:
    - Version: 0.5.0
    - Path: /config/www/owncloud/apps/federatedfilesharing
  - federation:
    - Version: 0.1.0
    - Path: /config/www/owncloud/apps/federation
  - files:
    - Version: 1.5.2
    - Path: /config/www/owncloud/apps/files
  - files_external:
    - Version: 0.8.0
    - Path: /config/www/owncloud/apps/files_external
  - files_mediaviewer:
    - Version: 1.0.4
    - Path: /config/www/owncloud/apps/files_mediaviewer
  - files_sharing:
    - Version: 0.14.0
    - Path: /config/www/owncloud/apps/files_sharing
  - files_trashbin:
    - Version: 0.9.1
    - Path: /config/www/owncloud/apps/files_trashbin
  - files_versions:
    - Version: 1.3.0
    - Path: /config/www/owncloud/apps/files_versions
  - firstrunwizard:
    - Version: 1.2.0
    - Path: /config/www/owncloud/apps/firstrunwizard
  - gallery:
    - Version: 16.1.1
    - Path: /config/www/owncloud/apps-external/gallery
  - market:
    - Version: 0.6.1
    - Path: /config/www/owncloud/apps/market
  - notifications:
    - Version: 0.5.4
    - Path: /config/www/owncloud/apps/notifications
  - password_policy:
    - Version: 2.1.3
    - Path: /config/www/owncloud/apps-external/password_policy
  - provisioning_api:
    - Version: 0.5.0
    - Path: /config/www/owncloud/apps/provisioning_api
  - systemtags:
    - Version: 0.3.0
    - Path: /config/www/owncloud/apps/systemtags
  - updatenotification:
    - Version: 0.2.1
    - Path: /config/www/owncloud/apps/updatenotification
Disabled:
  - encryption:
    - Path: /config/www/owncloud/apps/encryption
  - external:
    - Path: /config/www/owncloud/apps/external
  - user_external:
    - Path: /config/www/owncloud/apps/user_external
  - windows_network_drive:
    - Path: /config/www/owncloud/apps-external/windows_network_drive
yes, local
no
no
Chrome
Windows 10
2022/03/14 12:20:30 [error] 533#533: *505 open() "/config/www/owncloud/favicon.ico" failed (2: No such file or directory), client: MYIP, server: _, request: "GET /favicon.ico HTTP/1.1", host: "mydomain.tld"
Nothing really useful in there just a bunch of stuff thats too hard to clean up to post publicly.
Thank you
  • How did the update fail? You should have received some error messages, what were they?
  • How did you restore to the older version?
  • Did you also reset the database container to the pre-update state?
  • What’s the current docker log saying? ownCloud log is also necessary
  • What is the browser development console saying in the network tab? There should be some more obvious errors, pointing you to the correct log lines on the server.
This is what you’ll have to do?
The webserver crashed to internal server error. I kept waiting for 1 day hoping it would finish in the background but when I restarted the container after 1 day it went to internal server error.
The way it was described everywhere I looked: I re downloaded everything and imported the backup of my config. So I did this: Restoring ownCloud
I restored the database from a backup just before the update
No errors in docker log, everything as it should be.
Logs were empty but after restarting everything a couple of times I finally got an output:
{"reqId":"e3b0fbed-7e36-4d70-b1e9-b338807b88f1","level":3,"time":"2022-03-14T10:08:20+00:00","remoteAddr":"192.168.1.3","user":"--","app":"PHP","method":"GET","url":"\/index.php","message":"include(\/config\/www\/owncloud\/lib\/composer\/composer\/..\/..\/..\/core\/Controller\/SetupController.php): failed to open stream: No such file or directory at \/config\/www\/owncloud\/lib\/composer\/composer\/ClassLoader.php#444"}
{"reqId":"e3b0fbed-7e36-4d70-b1e9-b338807b88f1","level":3,"time":"2022-03-14T10:08:20+00:00","remoteAddr":"192.168.1.3","user":"--","app":"PHP","method":"GET","url":"\/index.php","message":"include(): Failed opening '\/config\/www\/owncloud\/lib\/composer\/composer\/..\/..\/..\/core\/Controller\/SetupController.php' for inclusion (include_path='\/config\/www\/owncloud\/apps') at \/config\/www\/owncloud\/lib\/composer\/composer\/ClassLoader.php#444"}
{"reqId":"e3b0fbed-7e36-4d70-b1e9-b338807b88f1","level":3,"time":"2022-03-14T10:08:20+00:00","remoteAddr":"192.168.1.3","user":"--","app":"index","method":"GET","url":"\/index.php","message":"Exception: {\"Exception\":\"Error\",\"Message\":\"Class 'OC\\\\Core\\\\Controller\\\\SetupController' not found\",\"Code\":0,\"Trace\":\"#0 \\\/config\\\/www\\\/owncloud\\\/index.php(54): OC::handleRequest()\\n#1 {main}\",\"File\":\"\\\/config\\\/www\\\/owncloud\\\/lib\\\/base.php\",\"Line\":863}"}
{"reqId":"e3b0fbed-7e36-4d70-b1e9-b338807b88f1","level":3,"time":"2022-03-14T10:08:20+00:00","remoteAddr":"192.168.1.3","user":"--","app":"PHP","method":"GET","url":"\/index.php","message":"file_get_contents(\/config\/www\/owncloud\/core\/js\/core.json): failed to open stream: No such file or directory at \/config\/www\/owncloud\/lib\/private\/legacy\/template.php#162"}
{"reqId":"e3b0fbed-7e36-4d70-b1e9-b338807b88f1","level":3,"time":"2022-03-14T10:08:20+00:00","remoteAddr":"192.168.1.3","user":"--","app":"core","method":"GET","url":"\/index.php","message":"Exception: {\"Exception\":\"Error\",\"Message\":\"Class 'OC\\\\Core\\\\Controller\\\\SetupController' not found\",\"Code\":0,\"Trace\":\"#0 \\\/config\\\/www\\\/owncloud\\\/index.php(54): OC::handleRequest()\\n#1 {main}\",\"File\":\"\\\/config\\\/www\\\/owncloud\\\/lib\\\/base.php\",\"Line\":863}"}
{"reqId":"e3b0fbed-7e36-4d70-b1e9-b338807b88f1","level":3,"time":"2022-03-14T10:08:20+00:00","remoteAddr":"192.168.1.3","user":"--","app":"core","method":"GET","url":"\/index.php","message":"Exception: {\"Exception\":\"Exception\",\"Message\":\"Cannot read core\\\/js\\\/core.json\",\"Code\":0,\"Trace\":\"#0 \\\/config\\\/www\\\/owncloud\\\/lib\\\/private\\\/legacy\\\/template.php(83): OC_Template::initTemplateEngine('error')\\n#1 \\\/config\\\/www\\\/owncloud\\\/lib\\\/private\\\/legacy\\\/template.php(371): OC_Template->__construct('', 'exception', 'error', false)\\n#2 \\\/config\\\/www\\\/owncloud\\\/index.php(76): OC_Template::printExceptionErrorPage(Object(Error))\\n#3 {main}\",\"File\":\"\\\/config\\\/www\\\/owncloud\\\/lib\\\/private\\\/legacy\\\/template.php\",\"Line\":174}"}
Not sure if this is what you meant but here you go:
Uncaught TypeError: Cannot read properties of undefined (reading 'enabledPreviewProviders')
    at Module.<anonymous> (files_mediaviewer_init.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c:1:1790)
    at t (files_mediaviewer_init.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c:1:110)
    at Object.<anonymous> (files_mediaviewer_init.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c:1:987)
    at files_mediaviewer_init.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c:1:902
    at files_mediaviewer_init.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c:1:911
shareconfigmodel.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c:24 Uncaught ReferenceError: oc_appconfig is not defined
    at shareconfigmodel.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c:24:33
    at shareconfigmodel.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c:193:3
snap.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c:391 Uncaught TypeError: Cannot read properties of null (reading 'style')
    at Object.x (snap.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c:391:42)
    at Object.easeTo (snap.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c:348:42)
    at Core.close (snap.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c:693:35)
    at toggleSnapperOnSize (js.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c:1653:13)
    at HTMLDocument.initCore (js.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c:1663:3)
    at j (jquery.js:3099:30)
    at Object.fireWith [as resolveWith] (jquery.js:3211:7)
    at Function.ready (jquery.js:3417:13)
    at HTMLDocument.I (jquery.js:3433:9)
cloud.domain.tld/:1          Failed to load resource: the server responded with a status of 500 ()
/favicon.ico:1          Failed to load resource: the server responded with a status of 404 ()
    at later (underscore.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c:892:31)
    at underscore.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c:829:19
Does that maybe help? Thanks
This has to create log entries in Apache and perhaps also the ownCloud log. Perhaps also double check the proxy, as docker containers are usually deployed behind a reverse proxy, for issues.
This output looks more like the console output. Make sure to switch to the network tab, then you can click on the exact requests that create the 500 server error responses.
  • Can you exec into the container and run occ status?
  • Double check that all containers (owncloud/mysql/redis) are showing as running and not restarting?
I run an nginx reverse proxy that’s true. But no errors there.
  • Can you exec into the container and run occ status ?
root@781c9a4acf42:/config/www/owncloud# sudo -u abc ./occ status
  - installed: true
  - first_install_version: 10.8.0.4
  - version: 10.8.0.4
  - versionstring: 10.8.0
  - edition: Community
It’s a unified container which includes everything: https://registry.hub.docker.com/r/dlandon/owncloud/
I got this
<div id="app-navigation">
	<ul class="with-icon">
				<li data-id="files" class="nav-files">
			<a href="#"
				class="nav-icon-files svg">
				Alle Dateien			</a>
		</li>
				<li data-id="favorites" class="nav-favorites">
			<a href="#"
				class="nav-icon-favorites svg">
				Favoriten			</a>
		</li>
				<li data-id="sharingin" class="nav-sharingin">
			<a href="#"
				class="nav-icon-sharingin svg">
				Mit Dir geteilt			</a>
		</li>
				<li data-id="sharingout" class="nav-sharingout">
			<a href="#"
				class="nav-icon-sharingout svg">
				Von Dir geteilt			</a>
		</li>
				<li data-id="sharinglinks" class="nav-sharinglinks">
			<a href="#"
				class="nav-icon-sharinglinks svg">
				Geteilt über einen Link			</a>
		</li>
				<li data-id="systemtagsfilter" class="nav-systemtagsfilter">
			<a href="#"
				class="nav-icon-systemtagsfilter svg">
				Tags			</a>
		</li>
				<li data-id="extstoragemounts" class="nav-extstoragemounts">
			<a href="#"
				class="nav-icon-extstoragemounts svg">
				Externer Speicher			</a>
		</li>
				<li data-id="trashbin" class="nav-trashbin">
			<a href="#"
				class="nav-icon-trashbin svg">
				Gelöschte Dateien			</a>
		</li>
			</ul>
	<div id="app-settings">
		<div id="app-settings-header">
			<button class="settings-button" data-apps-slide-toggle="#app-settings-content">
				Einstellungen			</button>
		</div>
		<div id="app-settings-content">
			<div id="files-setting-showhidden">
				<input class="checkbox" id="showhiddenfilesToggle" checked="checked" type="checkbox">
				<label for="showhiddenfilesToggle">Versteckte Dateien anzeigen</label>
			</div>
			<label for="webdavurl">WebDAV</label>
			<input id="webdavurl" type="text" readonly="readonly" value="https://cloud.domain.tld/remote.php/dav/files/marco/" />
			<em><!DOCTYPE html>
<html class="ng-csp" data-placeholder-focus="false" lang="de_CH" >
	<head data-requesttoken="">
		<meta charset="utf-8">
		<title>
		ownCloud		</title>
		<meta http-equiv="X-UA-Compatible" content="IE=edge">
		<meta name="referrer" content="never">
		<meta name="viewport" content="width=device-width, minimum-scale=1.0, maximum-scale=1.0">
					<meta name="apple-itunes-app" content="app-id=1359583808">
				<meta name="theme-color" content="#041e42">
		<link rel="icon" href="/core/img/favicon.ico">
		<link rel="apple-touch-icon-precomposed" href="/core/img/favicon-touch.png">
		<link rel="mask-icon" sizes="any" href="/core/img/favicon-mask.svg" color="#041e42">
					<link rel="stylesheet" href="/core/vendor/select2/select2.css?v=0aefb58b05a414a7e6365bfbc0ad1f9c">
					<link rel="stylesheet" href="/core/css/styles.css?v=0aefb58b05a414a7e6365bfbc0ad1f9c">
					<link rel="stylesheet" href="/core/css/inputs.css?v=0aefb58b05a414a7e6365bfbc0ad1f9c">
					<link rel="stylesheet" href="/core/css/header.css?v=0aefb58b05a414a7e6365bfbc0ad1f9c">
					<link rel="stylesheet" href="/core/css/icons.css?v=0aefb58b05a414a7e6365bfbc0ad1f9c">
					<link rel="stylesheet" href="/core/css/fonts.css?v=0aefb58b05a414a7e6365bfbc0ad1f9c">
					<link rel="stylesheet" href="/core/css/apps.css?v=0aefb58b05a414a7e6365bfbc0ad1f9c">
					<link rel="stylesheet" href="/core/css/global.css?v=0aefb58b05a414a7e6365bfbc0ad1f9c">
					<link rel="stylesheet" href="/core/css/fixes.css?v=0aefb58b05a414a7e6365bfbc0ad1f9c">
					<link rel="stylesheet" href="/core/css/multiselect.css?v=0aefb58b05a414a7e6365bfbc0ad1f9c">
					<link rel="stylesheet" href="/core/css/mobile.css?v=0aefb58b05a414a7e6365bfbc0ad1f9c">
					<link rel="stylesheet" href="/core/vendor/jquery-ui/themes/base/jquery-ui.css?v=0aefb58b05a414a7e6365bfbc0ad1f9c">
					<link rel="stylesheet" href="/core/css/jquery-ui-fixes.css?v=0aefb58b05a414a7e6365bfbc0ad1f9c">
					<link rel="stylesheet" href="/core/css/tooltip.css?v=0aefb58b05a414a7e6365bfbc0ad1f9c">
					<link rel="stylesheet" href="/core/css/share.css?v=0aefb58b05a414a7e6365bfbc0ad1f9c">
					<link rel="stylesheet" href="/apps/files_versions/css/versions.css?v=0aefb58b05a414a7e6365bfbc0ad1f9c">
					<link rel="stylesheet" href="/apps/firstrunwizard/css/colorbox.css?v=0aefb58b05a414a7e6365bfbc0ad1f9c">
					<link rel="stylesheet" href="/apps/firstrunwizard/css/firstrunwizard.css?v=0aefb58b05a414a7e6365bfbc0ad1f9c">
					<link rel="stylesheet" href="/apps-external/gallery/css/slideshow.css?v=0aefb58b05a414a7e6365bfbc0ad1f9c">
					<link rel="stylesheet" href="/apps-external/gallery/css/gallerybutton.css?v=0aefb58b05a414a7e6365bfbc0ad1f9c">
					<link rel="stylesheet" href="/apps/notifications/css/styles.css?v=0aefb58b05a414a7e6365bfbc0ad1f9c">
					<link rel="stylesheet" href="/core/css/jquery.ocdialog.css?v=0aefb58b05a414a7e6365bfbc0ad1f9c">
					<link rel="stylesheet" href="/apps/files/css/files.css?v=0aefb58b05a414a7e6365bfbc0ad1f9c">
					<link rel="stylesheet" href="/apps/files/css/upload.css?v=0aefb58b05a414a7e6365bfbc0ad1f9c">
					<link rel="stylesheet" href="/apps/files/css/mobile.css?v=0aefb58b05a414a7e6365bfbc0ad1f9c">
					<link rel="stylesheet" href="/apps/files/css/detailsView.css?v=0aefb58b05a414a7e6365bfbc0ad1f9c">
					<link rel="stylesheet" href="/apps/files_sharing/css/sharedfilelist.css?v=0aefb58b05a414a7e6365bfbc0ad1f9c">
					<link rel="stylesheet" href="/apps/files_external/css/external.css?v=0aefb58b05a414a7e6365bfbc0ad1f9c">
					<link rel="stylesheet" href="/apps/files_trashbin/css/trash.css?v=0aefb58b05a414a7e6365bfbc0ad1f9c">
					<link rel="stylesheet" href="/apps/comments/css/comments.css?v=0aefb58b05a414a7e6365bfbc0ad1f9c">
					<link rel="stylesheet" href="/apps/files_sharing/css/sharetabview.css?v=0aefb58b05a414a7e6365bfbc0ad1f9c">
					<link rel="stylesheet" href="/core/css/systemtags.css?v=0aefb58b05a414a7e6365bfbc0ad1f9c">
					<link rel="stylesheet" href="/apps/systemtags/css/systemtagsfilelist.css?v=0aefb58b05a414a7e6365bfbc0ad1f9c">
									<script src="/core/vendor/jquery/dist/jquery.min.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/vendor/jquery-migrate/jquery-migrate.min.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/vendor/jquery-ui/ui/jquery-ui.custom.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/vendor/underscore/underscore.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/vendor/moment/min/moment-with-locales.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/vendor/handlebars/handlebars.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/vendor/blueimp-md5/js/md5.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/vendor/bootstrap/js/tooltip.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/vendor/backbone/backbone.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/vendor/es6-promise/es6-promise.auto.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/vendor/davclient.js/lib/client.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/vendor/clipboard/dist/clipboard.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/vendor/bowser/src/bowser.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/jquery.ocdialog.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/oc-dialogs.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/js.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/l10n.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/l10n/de_CH.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/octemplate.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/eventsource.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/config.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/search/js/search.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/oc-requesttoken.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/apps.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/mimetype.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/mimetypelist.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/vendor/snapjs/dist/latest/snap.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/vendor/select2/select2.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/oc-backbone.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/oc-backbone-webdav.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/placeholder.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/jquery.avatar.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files_mediaviewer/l10n/de_CH.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files_mediaviewer/js/files_mediaviewer_init.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/shareconfigmodel.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/sharemodel.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/sharescollection.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/shareitemmodel.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/sharedialogresharerinfoview.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/sharedialoglinklistview.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/sharedialoglinkshareview.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/sharedialogmailview.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/sharedialoglinksocialview.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/sharedialoglinkexpirationview.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/sharedialogshareelistview.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/sharedialogview.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/share.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/user.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/firstrunwizard/js/jquery.colorbox.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/firstrunwizard/js/firstrunwizard.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps-external/gallery/js/vendor/bigshot/bigshot-compressed.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps-external/gallery/js/vendor/dompurify/src/purify.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps-external/gallery/js/galleryutility.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps-external/gallery/js/galleryfileaction.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps-external/gallery/js/slideshow.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps-external/gallery/js/slideshowcontrols.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps-external/gallery/js/slideshowzoomablepreview.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps-external/gallery/js/gallerybutton.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps-external/gallery/js/rotate.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps-external/gallery/js/rotation_cup.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/notifications/l10n/de_CH.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/notifications/js/app.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/notifications/js/notification.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps-external/password_policy/l10n/de_CH.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps-external/password_policy/js/notification.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/files/fileinfo.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/files/client.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files/l10n/de_CH.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files/js/app.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files/js/file-upload.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files/js/newfilemenu.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files/js/jquery.fileupload.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files/js/jquery-visibility.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files/js/fileinfomodel.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files/js/filesummary.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files/js/breadcrumb.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files/js/filelist.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files/js/search.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files/js/favoritesfilelist.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files/js/tagsplugin.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files/js/favoritesplugin.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files/js/filelockplugin.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files/js/detailfileinfoview.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files/js/detailtabview.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files/js/mainfileinfodetailview.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files/js/detailsview.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files/js/locktabview.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files/js/fileactions.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files/js/fileactionsmenu.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files/js/fileactionsapplicationselectmenu.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files/js/files.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files/js/keyboardshortcuts.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files/js/navigation.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files_sharing/l10n/de_CH.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files_sharing/js/app.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files_sharing/js/sharedfilelist.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files_external/l10n/de_CH.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files_external/js/statusmanager.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files_external/js/rollingqueue.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files_external/js/app.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files_external/js/mountsfilelist.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files_trashbin/l10n/de_CH.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files_trashbin/js/app.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files_trashbin/js/filelist.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/comments/l10n/de_CH.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/comments/js/app.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/comments/js/commentmodel.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/comments/js/commentcollection.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/comments/js/commentsummarymodel.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/comments/js/commentstabview.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/comments/js/filesplugin.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/comments/js/activitytabviewplugin.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files_sharing/js/share.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files_sharing/js/sharetabview.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files_sharing/js/external.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files_versions/l10n/de_CH.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files_versions/js/versionmodel.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files_versions/js/versioncollection.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files_versions/js/versionstabview.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/files_versions/js/filesplugin.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/select2-toggleselect.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/systemtags/systemtags.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/systemtags/systemtagmodel.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/systemtags/systemtagsmappingcollection.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/systemtags/systemtagscollection.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/systemtags/systemtagsinputfield.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/core/js/systemtags/systemtagslist.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/systemtags/l10n/de_CH.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/systemtags/js/app.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/systemtags/js/systemtagsfilelist.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/systemtags/js/filesplugin.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/systemtags/js/systemtagstabview.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					<script src="/apps/systemtags/js/systemtagsinfoview.js?v=0aefb58b05a414a7e6365bfbc0ad1f9c"></script>
					</head>
	<body id="body-login"  >
		<noscript>
	<div id="nojavascript">
		<div>
			Diese Anwendung benötigt zum ordnungsgemässen Betrieb JavaScript. Bitte <a href="http://enable-javascript.com/" target="_blank" rel="noreferrer">aktiviere JavaScript</a> und lade die Seite neu.		</div>
	</div>
</noscript>
		<div class="wrapper">
			<div class="v-align">
									<header role="banner">
						<div id="header">
							<div class="logo">
								<h1 class="hidden-visually">
									ownCloud								</h1>
							</div>
							<div id="logo-claim" style="display:none;"></div>
						</div>
					</header>
								<span class="error error-wide">
	<h2><strong>Interner Serverfehler</strong></h2>
		<p>Der Server hat einen internen Fehler und konnte Ihre Anfrage nicht vervollständigen.</p>
		<p>Bitte wende dich an den Serveradministrator, sollte dieser Fehler mehrfach auftreten und füge deiner Anfrage die unten stehenden technischen Details bei.</p>
		<p>Weitere Details können im <a target="_blank" rel="noreferrer" href="https://doc.owncloud.com/server/10.8/go.php?to=admin-logfiles">Serverprotokoll</a> gefunden werden.</p>
	<br>
	<h2><strong>Technische Details</strong></h2>
	<ul>
		<li>Entfernte Adresse: 192.168.1.3</li>
		<li>Anforderungskennung: 7I9MpcHHSNguoxrpmOT9</li>
			</ul>
	</span>
			</div>
		</div>
		<footer role="contentinfo">
			<p class="info">
				<a href="https://owncloud.org" target="_blank" rel="noreferrer">ownCloud</a> &ndash; Ein sicherer Speicherplatz für deine ganzen Daten.			</p>
		</footer>
	</body>
</html>
I don’t know anymore… If I begin from scratch all together I lose all settings etc or would that be advised?
Oh, then I’d recommend to open an issue in their repository:
Thanks, I was able to solve it.
For anyone interested: I was somehow stuck in between 2 updates. I followed instructions from the creator of the docker container which was to do a manual update as stated here:
The update manually then went through fine and WebUI loads correctly again.
