WebUI not showing files even though webdav and other clients are working fine
1.Login to webUI successfully and files are not there
2.
3.
Expecting files to be there
Files missing in WebUI but appear in WebDav and desktop client. All other webUI functions appear to work properly.
Until you make a change on the desktop. Then I get an error : “Server replied file is locked”.
Operating system: “Ubuntu precise (12.04.5 LTS)” w/all the latest patches
Web server: Apache 2.2.22
Database: Mysql 5.5.54
PHP version: 5.4.45-4+
ownCloud version (see ownCloud admin page): 9.1.5.2
Updated from an older ownCloud or fresh install: Fresh install UI + upgraded DB
ownCloud configuration
    "system": {
        "instanceid": "xxx",
        "trusted_domains": [
            "mydomain",
            "mydomain.mydomain.com",
            "mydomain2.com"
        "datadirectory": "\/data2\/owncloud",
        "overwrite.cli.url": "https:\/\/mydomain\/owncloud",
        "dbtype": "mysql",
        "version": "9.1.5.2",
        "dbname": "owncloude",
        "dbhost": "localhost",
        "dbtableprefix": "oc_",
        "logtimezone": "UTC",
        "installed": true,
        "theme": "",
        "loglevel": 2,
        "maintenance": false,
        "singleuser": false,
        "mail_from_address": "myname",
        "mail_smtpmode": "php",
        "mail_domain": "gmail.com"
mydomain.com/:56 GET https://mydomain.com:4545/owncloud/core/vendor/davclient.js/lib/client.js?v=b015ab17af04587a6899a57c4e57ad2d
jquery-migrate.min.js?v=b015ab1.:2 JQMIGRATE: Migrate is installed, version 1.4.0
mydomain.com/:56 GET https://mydomain.com:4545/owncloud/core/vendor/davclient.js/lib/client.js?v=b015ab17af04587a6899a57c4e57ad2d 500 (Internal Server Error)
client.js?v=b015ab1.:59 Uncaught ReferenceError: dav is not defined
    at Client (client.js?v=b015ab1.:59)
    at Object.OC.Files.getClient (client.js?v=b015ab1.:744)
    at Object.initialize (app.js?v=b015ab1.:90)
    at app.js?v=b015ab1.:314
    at underscore.js?v=b015ab1.:768
Client @ client.js?v=b015ab1.:59
OC.Files.getClient @ client.js?v=b015ab1.:744
initialize @ app.js?v=b015ab1.:90
(anonymous) @ app.js?v=b015ab1.:314
(anonymous) @ underscore.js?v=b015ab1.:768
###php-errors.log content
[04-May-2017 17:00:04 America/Denver] PHP Warning:  Module 'apc' already loaded in Unknown on line 0
[04-May-2017 17:00:16 America/Denver] PHP Parse error:  syntax error, unexpected 'version' (T_STRING) in /var/www/owncloud/core/vendor/davclient.js/lib/client.js on line 58
Integrity status for oC9+
