What means "is out of base uri"?
I have the latest stable Server Version (10.0.10) and the latest Windows Client (2.5.1).
2,8GB is uploaded, but with 28 files I get an error like this:
Server hat “403 Forbidden” auf “MOVE https://cloud.user.com/remote.php/dav/uploads/user/1101239256/.file” geantwortet (Requested uri (//remote.php/dav/files/user/HiFi/Equipment/Revox_B126_B226-S_Serv.pdf) is out of base uri (/remote.php/dav/))
I would be glad to get help
Sounds like https://github.com/owncloud/client/issues/6904
Fix should be included in the next version.
This only happens on Windows when you enter the server URL with trailing “/”. As a workaround, you could remove the trailing “/” from the server URL in your config file:
https://doc.owncloud.org/desktop/2.5/advancedusage.html#configuration-file
i did the following search: Issue search results · GitHub and found:
Yeah - THIS IS IT :sunny:
Thank you so much!!!
