2.
3.
Operating system: ubuntu 16.0.4
Database: mysql
PHP version: 7
ownCloud version (see ownCloud admin page): 9.1.1
Special configuration (external storage, external authentication, reverse proxy, server-side-encryption): none I do have HTTPS enabled
I am looking at the hardening owncloud security and theres a script that says I need to insert my own htuser and htgroup. I tried the php.info deal and that for whatever reason did not work for me when I used the url.
Well I have looked and looked and I cannot find these values anywhere. I know where the .ocdata path is … I just need to double check the htuser and the htgroup.
My install is /var/www/owncloud if that helps
Integrity status for oC9+
paste the results here.
