- Tell us what happens
When I download a document I can sometimes open it with an app, but I can’t find the location the file is stored at. For example I may want to move a downloaded pem, pdf or jpeg to another folder for offline use.
Expected behavior
- Tell us what should happen
All downloaded content should be accessible to the file manager for movement to other locations as needed.
- Download a pem file
- Search for it with file manager
- Nothing shows up in the search
Can this problem be reproduced with the official owncloud server?
Don’t know. Not going to send a certificate to an unknown public place.
Environment data
Android version:
10
Device model:
SM-G960N
Stock or customized system:
Stock
ownCloud app version:
4.1.1
ownCloud server version:
4.2.1.13040
