New Sync
The folder is used in a folder sync connection! Please pick another one!
- Link to folder
Operating system:Raspberry Pi OS / Windows 11
Web server: nginx
Database:Mariadb
PHP version:7.4
ownCloud version:10
Storage backend (external storage):1gig ssd
Client version:3
Operating system:Windows 11
OS language:
Installation path of client:
logs.
Client logfile: Output of
owncloud --logwindow
orowncloud --logfile log.txt
(On Windows usingcmd.exe
, you might need to firstcd
into the ownCloud directory)
(See also http://doc.owncloud.org/desktop/2.2/troubleshooting.html#client-logfile ) -
Web server error log:
I have set up ownCloud on a Raspberry Pi 3B Plus using nginx and Mariadb and am administering it from a Windows 11 PC using the Windows desktop app and web access. I have run into the ‘Folder Is Used in a Folder Sync Connection’ and while I understand the problem and its solution, I can’t find the .sync_journal.db file to correct the entries. Any help would be appreciated.
