Today we decided to upgrade our OC Server from latest 8 (8.2.9) to 9.0.6 and then go to 9.1 however after uploading 9.0.6 files, we only had blank page … I searched alot but I have not found my solution yet.
This is what we did :
1- Disabled all apps
2- Uploaded OC 9.0.6 files using FTP
Our Server details :
PHP 7.0 -or- 5.6 (we have both)
Cloudlinux (latest)
LiteSpeed
I would really appreciate if you help me to solve this issue … I am really worried that I have to stick with 8 for ever …
Did you follow the upgrade instructions, creating a new owncloud folder and copying your old config.php to its’ config subfolder (after backing everything up, of course)?
I think it’s better to extract the owncloud archive directly on your server rather than transferring the individual files via FTP. Try that, instead.
Well I tried both … using FTP and buy unzipping the OwnCloud Files directly on the server.
I have not tried renaming the old directory and uploading the new one … I completely removed the old files (exept data folder which is not located inside the owncloud installation path) and /config/* directory. Then uploaded the new files to the server using FTP -or- unpacking the zip file directly on the server.
In both instances, when I try to upgrade from 8.2.9 to 9.0.7 , it stuck in this step : “Updated “provisioning_api” to 0.4.1” and then shows this error : “An error occurred.”
