White page after manual upgrade to 9.1 - solved, when htaccess is disabled
I use oC on an hosted environment at 1&1, Germany.
After manually upgrading from 9.0.3 to 9.1, at the first attempt to log-in there appeared the upgrade-process, which completed successfully, but, when redirecting me to my website, only a white page appears.
When I disable the original htaccess (which I did not alter) by renaming it in htaccess.txt, everything is fine, but with .htacess - white page.
Here is the htaccess:
SetEnvIfNoCase ^Authorization$ “(.+)” XAUTHORIZATION=$1
RequestHeader set XAuthorization %{XAUTHORIZATION}e env=XAUTHORIZATION
SetEnvIfNoCase Authorization “(.+)” HTTP_AUTHORIZATION=$1
# Add security and privacy related headers Header set X-Content-Type-Options "nosniff" Header set X-XSS-Protection "1; mode=block" Header set X-Robots-Tag "none" Header set X-Frame-Options "SAMEORIGIN" Header set X-Download-Options "noopen" Header set X-Permitted-Cross-Domain-Policies "none" SetEnv modHeadersAvailable true
Add cache control for CSS and JS files
<FilesMatch “.(css|js)$”>
Header set Cache-Control “max-age=7200, public”
php_value upload_max_filesize 513M
php_value post_max_size 513M
php_value memory_limit 512M
php_value mbstring.func_overload 0
php_value always_populate_raw_post_data -1
php_value default_charset ‘UTF-8’
php_value output_buffering 0
SetEnv htaccessWorking true
RewriteEngine on
RewriteRule .* - [env=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
RewriteRule ^.well-known/host-meta /public.php?service=host-meta [QSA,L]
RewriteRule ^.well-known/host-meta.json /public.php?service=host-meta-json [QSA,L]
RewriteRule ^.well-known/carddav /remote.php/dav/ [R=301,L]
RewriteRule ^.well-known/caldav /remote.php/dav/ [R=301,L]
RewriteRule ^remote/(.) remote.php [QSA,L]
RewriteRule ^(build|tests|config|lib|3rdparty|templates)/.
- [R=404,L]
RewriteCond %{REQUEST_URI} !^/.well-known/acme-challenge/.*
RewriteRule ^(.|autotest|occ|issue|indie|db_|console).* - [R=404,L]
Rewrite rules for front_controller_active
Options -MultiViews
RewriteRule ^core/js/oc.js$ index.php/core/js/oc.js [PT,E=PATH_INFO:$1]
RewriteRule ^core/preview.png$ index.php/core/preview.png [PT,E=PATH_INFO:$1]
RewriteCond %{REQUEST_FILENAME} !.(css|js|svg|gif|png|html|ttf|woff|ico)$
RewriteCond %{REQUEST_FILENAME} !core/img/favicon.ico$
RewriteCond %{REQUEST_FILENAME} !/remote.php
RewriteCond %{REQUEST_FILENAME} !/public.php
RewriteCond %{REQUEST_FILENAME} !/cron.php
RewriteCond %{REQUEST_FILENAME} !/core/ajax/update.php
RewriteCond %{REQUEST_FILENAME} !/status.php
RewriteCond %{REQUEST_FILENAME} !/ocs/v1.php
RewriteCond %{REQUEST_FILENAME} !/ocs/v2.php
RewriteCond %{REQUEST_FILENAME} !/updater/
RewriteCond %{REQUEST_FILENAME} !/ocs-provider/
RewriteRule .* index.php [PT,E=PATH_INFO:$1]
AddType image/svg+xml svg svgz
AddEncoding gzip svgz
DirectoryIndex index.php index.html
AddDefaultCharset utf-8
Options -Indexes
ModPagespeed Off
DO NOT CHANGE ANYTHING ABOVE THIS LINE
ErrorDocument 403 /oc/core/templates/403.php
ErrorDocument 404 /oc/core/templates/404.php
There also is a .user.ini, which reads
`upload_max_filesize=513M
post_max_size=513M
memory_limit=512M
mbstring.func_overload=0
always_populate_raw_post_data=-1
default_charset=‘UTF-8’
output_buffering=0
Any idea, how to solve that prob?
Thank You so much,
Steffen
have a look at the following FAQ. Without the matching logentries to this white page its nearly impossible to guess whats wrong here.
Hi, RealRancor,
thanks for Your reply.
As the owncloud-log is about 10 MB, I firsthand tried a complete new installation of oC 9.1 and a copy of my data afterwards which worked out fine until now.
Steffen
