i want to integrate the microsoft office online server. the oos is up and running but i don`t know where to get the wopi key from? Is it just a random key i can create myself? And is the only place to put it in the config/config.php file?
Thank you very much for your help
Heiko
Hi, that is just a random string used for jwt computation
And yes, you will have to enter it in your config/config.php file
Hello pako81,
thanks for your help.
The problem is, no matter what I enter in config.php - for example for testing: ‘wopi.token.key’ => ‘123456789’,
After that, when is try to open a document in my owncloud, i get the error: This content is blocked. Contact the site owner to resolve the issue.
Any idea?
Thank you
