Writing to the "config" directory is not possible
  1. Reset root password on Centos7
  2. Reboot
  3. Access owncloud gui
I receive the following message,
Writing to the “config” directory is not possible
This can usually be fixed by giving the web server write access to the configuration directory
I checked the config directory ownership and apache is the owner and group owner
Operating system: CentOS 7
Web server: Apache
PHP version: 5.6.30
ownCloud version (see ownCloud admin page): 10
Special configuration (external storage, external authentication, reverse proxy, server-side-encryption): nothing special
Ok, problem solved by setting the selinux contexts again.
semanage fcontext -a -t httpd_sys_rw_content_t ‘/var/www/html/owncloud/data(/.)?’
semanage fcontext -a -t httpd_sys_rw_content_t '/var/www/html/owncloud/config(/.
semanage fcontext -a -t httpd_sys_rw_content_t ‘/var/www/html/owncloud/apps(/.)?’
semanage fcontext -a -t httpd_sys_rw_content_t '/var/www/html/owncloud/assets(/.
semanage fcontext -a -t httpd_sys_rw_content_t ‘/var/www/html/owncloud/.htaccess’
semanage fcontext -a -t httpd_sys_rw_content_t ‘/var/www/html/owncloud/.user.ini’
restorecon -Rv ‘/var/www/html/owncloud/’
