- Open shared-link with password
- check files contain in folder
- check file on NAS
Correct data in the folder should be displayed. (Folder name like “First example” is the same as the name of the pdf file “First example.pdf”).
It shows files that should be in another folder.
But the data is correctly located on the NAS
Ubuntu 14.04 LTS
Apache 2.4.17
mysql 5.7.35
PHP 5.6.16
l3iggs/owncloud latest version
l3iggs/owncloud image docker container
<?php
$CONFIG = array (
'instanceid' => 'deleted',
'passwordsalt' => 'deleted',
'secret' => 'deleted',
'trusted_domains' =>
array (
0 => 'ip:port',
1 => 'fqdn',
'datadirectory' => '/usr/share/webapps/owncloud/data',
'overwrite.cli.url' => 'https://ip:port',
'dbtype' => 'mysql',
'version' => 'deleted',
'dbname' => 'deleted',
'dbhost' => 'deleted',
'dbtableprefix' => 'deleted',
'dbuser' => 'deleted',
'dbpassword' => 'deleted',
'logtimezone' => 'UTC',
'installed' => true,
'loglevel' => 0,
'apps_paths' =>
array (
0 =>
array (
'path' => '/usr/share/webapps/owncloud/apps',
'url' => '/apps',
'writable' => false,
1 =>
array (
'path' => '/usr/share/webapps/owncloud/custom_apps',
'url' => '/custom_apps',
'writable' => true,
NAS - SMB
he Virtual Host Part from httpd-ssl.conf like that
<VirtualHost _default_:443>
# General setup for the virtual host
DocumentRoot "/srv/http"
ServerName www.example.com:443
ServerAdmin you@example.com
ErrorLog "/var/log/httpd/error_log"
TransferLog "/var/log/httpd/access_log"
And owncloud.conf like that
<IfModule mod_alias.c>
Alias /${TARGET_SUBDIR} /usr/share/webapps/owncloud/
</IfModule>
<Directory /usr/share/webapps/owncloud/>
Header always add Strict-Transport-Security "max-age=15768000; includeSubDomains; preload"
Options FollowSymlinks
AllowOverride all
Require all granted
php_admin_value open_basedir "/srv/http/:/home/:/tmp/:/usr/share/pear/:/usr/share/webapps/owncloud/:/etc/webapps/owncloud:/dev/urandom"
</Directory>
And a startServers.sh from the image
#!/usr/bin/env bash
if [ "$ENABLE_DAV" = true ] ; then
cat >> /etc/httpd/conf/httpd.conf <<EOF
Alias /dav "/home/httpd/html/dav"
<Directory "/home/httpd/html/dav">
DAV On
AllowOverride None
Options Indexes FollowSymLinks
Require all granted
</Directory>
EOF
"reqId":"e9QleU77evfFGkVmx574","remoteAddr":"xxx.xxx.xxx.xxx","app":"core","message":"Exception: {\"Exception\":\"Doctrine\\\\DBAL\\\\DBALException\",\"Message\":\"Failed to connect to the database: An exception occured in driver: SQLSTATE[HY000] [1862] Your password has expired. To log in you must change it using a client that supports expired passwords.\",\"Code\":0,\"Trace\":\"#0 \\\/usr\\\/share\\\/webapps\\\/owncloud\\\/3rdparty\\\/doctrine\\\/dbal\\\/lib\\\/Doctrine\\\/DBAL\\\/Connection.php(429): OC\\\\DB\\\\Connection->connect()\\n#1 \\\/usr\\\/share\\\/webapps\\\/owncloud\\\/3rdparty\\\/doctrine\\\/dbal\\\/lib\\\/Doctrine\\\/DBAL\\\/Connection.php(389): Doctrine\\\\DBAL\\\\Connection->getDatabasePlatformVersion()\\n#2 \\\/usr\\\/share\\\/webapps\\\/owncloud\\\/3rdparty\\\/doctrine\\\/dbal\\\/lib\\\/Doctrine\\\/DBAL\\\/Connection.php(328): Doctrine\\\\DBAL\\\\Connection->detectDatabasePlatform()\\n#3 \\\/usr\\\/share\\\/webapps\\\/owncloud\\\/3rdparty\\\/doctrine\\\/dbal\\\/lib\\\/Doctrine\\\/DBAL\\\/Connection.php(621): Doctrine\\\\DBAL\\\\Connection->getDatabasePlatform()\\n#4 \\\/usr\\\/share\\\/webapps\\\/owncloud\\\/lib\\\/private\\\/db\\\/connection.php(135): Doctrine\\\\DBAL\\\\Connection->setTransactionIsolation(2)\\n#5 \\\/usr\\\/share\\\/webapps\\\/owncloud\\\/3rdparty\\\/doctrine\\\/dbal\\\/lib\\\/Doctrine\\\/DBAL\\\/DriverManager.php(172): OC\\\\DB\\\\Connection->__construct(Array, Object(Doctrine\\\\DBAL\\\\Driver\\\\PDOMySql\\\\Driver), Object(Doctrine\\\\DBAL\\\\Configuration), Object(Doctrine\\\\Common\\\\EventManager))\\n#6 \\\/usr\\\/share\\\/webapps\\\/owncloud\\\/lib\\\/private\\\/db\\\/connectionfactory.php(118): Doctrine\\\\DBAL\\\\DriverManager::getConnection(Array, Object(Doctrine\\\\DBAL\\\\Configuration), Object(Doctrine\\\\Common\\\\EventManager))\\n#7 \\\/usr\\\/share\\\/webapps\\\/owncloud\\\/lib\\\/private\\\/server.php(327): OC\\\\DB\\\\ConnectionFactory->getConnection('mysql', Array)\\n#8 \\\/usr\\\/share\\\/webapps\\\/owncloud\\\/3rdparty\\\/pimple\\\/pimple\\\/src\\\/Pimple\\\/Container.php(112): OC\\\\Server->OC\\\\{closure}(Object(OC\\\\Server))\\n#9 \\\/usr\\\/share\\\/webapps\\\/owncloud\\\/lib\\\/private\\\/appframework\\\/utility\\\/simplecontainer.php(104): Pimple\\\\Container->offsetGet('DatabaseConnect...')\\n#10 \\\/usr\\\/share\\\/webapps\\\/owncloud\\\/lib\\\/private\\\/server.php(762): OC\\\\AppFramework\\\\Utility\\\\SimpleContainer->query('DatabaseConnect...')\\n#11 \\\/usr\\\/share\\\/webapps\\\/owncloud\\\/lib\\\/private\\\/db.php(42): OC\\\\Server->getDatabaseConnection()\\n#12 \\\/usr\\\/share\\\/webapps\\\/owncloud\\\/lib\\\/private\\\/server.php(235): OC_DB::getConnection()\\n#13 \\\/usr\\\/share\\\/webapps\\\/owncloud\\\/3rdparty\\\/pimple\\\/pimple\\\/src\\\/Pimple\\\/Container.php(112): OC\\\\Server->OC\\\\{closure}(Object(OC\\\\Server))\\n#14 \\\/usr\\\/share\\\/webapps\\\/owncloud\\\/lib\\\/private\\\/appframework\\\/utility\\\/simplecontainer.php(104): Pimple\\\\Container->offsetGet('AppConfig')\\n#15 \\\/usr\\\/share\\\/webapps\\\/owncloud\\\/lib\\\/private\\\/server.php(701): OC\\\\AppFramework\\\\Utility\\\\SimpleContainer->query('AppConfig')\\n#16 \\\/usr\\\/share\\\/webapps\\\/owncloud\\\/lib\\\/private\\\/util.php(410): OC\\\\Server->getAppConfig()\\n#17 \\\/usr\\\/share\\\/webapps\\\/owncloud\\\/lib\\\/private\\\/util.php(343): OC_Util::loadVersion()\\n#18 \\\/usr\\\/share\\\/webapps\\\/owncloud\\\/lib\\\/private\\\/defaults.php(52): OC_Util::getVersion()\\n#19 \\\/usr\\\/share\\\/webapps\\\/owncloud\\\/lib\\\/private\\\/template.php(81): OC_Defaults->__construct()\\n#20 \\\/usr\\\/share\\\/webapps\\\/owncloud\\\/lib\\\/private\\\/template.php(328): OC_Template->__construct('', 'exception', 'error', false)\\n#21 \\\/usr\\\/share\\\/webapps\\\/owncloud\\\/index.php(55): OC_Template::printExceptionErrorPage(Object(Doctrine\\\\DBAL\\\\DBALException))\\n#22 {main}\",\"File\":\"\\\/usr\\\/share\\\/webapps\\\/owncloud\\\/lib\\\/private\\\/db\\\/connection.php\",\"Line\":52}","level":3,"time":"2021-09-14T17:42:22+00:00","method":"GET","url":"\/index.php\/s\/AZ0Eeyp1QkXDyBC"}
