Hi there, excellent Owncloud masters!
So, I’m fairly new at this whole running an Owncloud server thing, and I’m having a few minor but irritating issues.
Issue:
The “X-Content-Type-Options” HTTP header is not configured to equal to “nosniff”. This is a potential security or privacy risk and we recommend adjusting this setting.
The “X-Frame-Options” HTTP header is not configured to equal to “SAMEORIGIN”. This is a potential security or privacy risk and we recommend adjusting this setting.
The problem is that these settings are already correct. When I check the headers with, for example, keycdn.com, then I find that the server reports:
X-FRAME-OPTIONS: SAMEORIGIN
X-Content-Type-Options: nosniff
X-XSS-Protection: 1; mode=block
- Install CentOs 7
- Install PHP 7
- Install Owncloud 10
4: Add all settings seemingly correctly.
No X-content errors should show up.
The "X-Content-Type-Options" HTTP header is not configured to equal to "nosniff". This is a potential security or privacy risk and we recommend adjusting this setting.
The "X-Frame-Options" HTTP header is not configured to equal to "SAMEORIGIN". This is a potential security or privacy risk and we recommend adjusting this setting.
CentOS Linux release 7.3.1611 (Core)
Apache 2.4.6
5.5.52-MariaDB
PHP 7.0.21
10.0.0 (Minor issue: It seems impossible to update top 1.0.2 despite the admin panel complaining that it wants to be updated.)
Fresh install
I used this repository: download.owncloud.com
Newbie status confirmed. I have no idea what this is or how to provide the answer :).
File simply says: No erros have been found
"system": {
"instanceid": "oc1i7yju93iq",
"trusted_domains": [
"filer.friab.se"
"datadirectory": "\/var\/www\/html\/owncloud\/data",
"overwrite.cli.url": "https:\/\/notreal.domain\/owncloud",
"dbtype": "mysql",
"version": "10.0.0.12",
"dbname": "owncloud",
"dbhost": "localhost",
"dbtableprefix": "oc_",
"logtimezone": "UTC",
"installed": true,
"maintenance": false,
"updater.secret": "***REMOVED SENSITIVE VALUE***",
"filelocking.enabled": true,
"redis": {
"host": "\/var\/run\/redis\/redis.sock",
"port": 0,
"timeout": 0
Enabled:
- activity: 2.3.3
- comments: 0.3.0
- configreport: 0.1.1
- dav: 0.2.8
- federatedfilesharing: 0.3.0
- federation: 0.1.0
- files: 1.5.1
- files_external: 0.7.0
- files_pdfviewer: 0.8.1
- files_sharing: 0.10.0
- files_texteditor: 2.1
- files_trashbin: 0.9.0
- files_versions: 1.3.0
- files_videoplayer: 0.9.8
- firstrunwizard: 1.1
- gallery: 15.0.0
- market: 0.1.0
- notifications: 0.3.0
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- templateeditor: 0.1
- updatenotification: 0.2.1
Disabled: - encryption
- example-theme
- external
- files_antivirus
- user_external
No
No
No
### Client configuration
**Browser:**
Firefox 54.0.1
**Operating system:**
Windows Server 2016 and Windows 10
### Logs
#### Web server error log
{“reqId”:“WXns6nAACIdLMFKLHdNwCgAAAAs”,“level”:3,“time”:“2017-07-27T13:38:50+00:00”,“remoteAddr”:“I”,“user”:“admin”,“app”:“PHP”,“method”:“GET”,“url”:“/owncloud/ocs/v2.php/apps/notifications/api/v1/notifications?format=json”,“message”:“Redis::connect(): connect() failed: No such file or directory at /var/www/html/owncloud/lib/private/RedisFactory.php#83”}
{“reqId”:“WXns6nAACIdLMFKLHdNwCgAAAAs”,“level”:3,“time”:“2017-07-27T13:38:50+00:00”,“remoteAddr”:“IP”,“user”:“admin”,“app”:“PHP”,“method”:“GET”,“url”:“/owncloud/ocs/v2.php/apps/notifications/api/v1/notifications?format=json”,“message”:“You are using a fallback implementation of the intl extension. Installing the native one is highly recommended instead. at /var/www/html/owncloud/lib/composer/patchwork/utf8/src/Patchwork/Utf8/Bootup/intl.php#18”}
{“reqId”:“WXns7CW4vqvy1iukxpjd0AAAAAA”,“level”:3,“time”:“2017-07-27T13:38:52+00:00”,“remoteAddr”:“IP”,“user”:“admin”,“app”:“PHP”,“method”:“GET”,“url”:“/owncloud/ocs/v2.php/apps/notifications/api/v1/notifications?format=json”,“message”:“Redis::connect(): connect() failed: No such file or directory at /var/www/html/owncloud/lib/private/RedisFactory.php#83”}
{“reqId”:“WXns7CW4vqvy1iukxpjd0AAAAAA”,“level”:3,“time”:“2017-07-27T13:38:53+00:00”,“remoteAddr”:“IP4”,“user”:“admin”,“app”:“PHP”,“method”:“GET”,“url”:“/owncloud/ocs/v2.php/apps/notifications/api/v1/notifications?format=json”,“message”:“You are using a fallback implementation of the intl extension. Installing the native one is highly recommended instead. at /var/www/html/owncloud/lib/composer/patchwork/utf8/src/Patchwork/Utf8/Bootup/intl.php#18”}
#### Browser log
If you think these are needed, then I’d be happy to add them as well.
