Your Data directory is not writable by ownCloud
Since a restore serveur Owncloud 10.0.4 on my VMware solution. I have this message in the index page :
Le problème de permissions peut généralement être résolu en donnant au serveur web un accès en écriture au répertoire racine
(I’m french, nobody is perfect !:wink:
The data folder is on the second hard disk. It’s mount correctly, The user “apache” can read/write on it.
[root@ocloud odata]# ll
total 20
drwxrwx—. 31 apache apache 4096 30 mars 14:11 data
drwx------. 2 apache apache 16384 24 janv. 11:38 lost+found
Do you have a idea ?
Thanks in advance.
how did you change the data dir?
did you follow this:
https://doc.owncloud.com/server/10.0/admin_manual/maintenance/manually-moving-data-folders.html?highlight=data%20directory
what is your config.php?
what is in your oc_storages table?
Can you look in your owncloud.log file and check what directory owncloud is trying to access and failing?
Thanks for your awnser.
No, I don’t move the directory.
The folder ocdata is a mount :
/dev/sdb1 /media/odata ext3 defaults 0 0
The log file is on the ocdata ? how I can move it ?
well, default dir is /owncloud/data - > so you had to move the data dir :slight_smile:
Yes, when a setup owncloud.
History:
1/Setup VM centos and install owncloud with data on /media/odata. and it worked perfectly
2/Stop vm
3/Export vm
4/ exployed vm / Start it and I have this message in my browser : Your Data directory is not writable by ownCloud.
The config.php
<?php $CONFIG = array ( 'updatechecker' => false, 'instanceid' => 'oc7vnt828mdn', 'passwordsalt' => 'oukSZdymAX/M5I0b7kAETSEtDbOO9QVx', 'secret' => 'H2BskcGMz+HkofHHu8UZKfUoId79fR36ubbe70Z19FWj1n2vAn', 'trusted_domains' => array ( 0 => 'ocloud', ), 'datadirectory' => '/media/odata/data', 'overwrite.cli.url' => 'https://ocloud/owncloud', 'dbtype' => 'mysql', 'version' => '10.0.4.4', 'dbname' => 'oclouddb', 'dbhost' => 'localhost', 'dbtableprefix' => 'oc_', 'dbuser' => 'oclouddbuser', 'dbpassword' => 'XXXXXXX', 'logtimezone' => 'UTC', 'installed' => true, 'ldapIgnoreNamingRules' => false, 'loglevel' => 3, );
can you execute this command to be sure:
chown -R apache:apache <and your data dir>
also this:
After chown it is the same thing
MariaDB
The log file is in the oc data directory, It doesn’t update since the issu.
I try with this parameters in the config.php
‘log_type’ => ‘syslog’,
But, I saw no log from owncloud…
I tried :
‘logfile’ => ‘/var/log/owncloud.log’,
No file was create when a restart apache and try to acces on onwcloud.
I don’t understand why my VM backup daosn’t work…
Can you tell me how you installed ownCloud and how you exported and imported the vm?
Maybe I would be able to recreate your setup and find the error
For export/import VM I used the vsphere client, VM shutdown.
there are this error in the message.log
Apr 5 09:59:27 ocloud setroubleshoot: SELinux is preventing httpd from write access on the directory data. For complete SELinux messages run: sealert -l 50a3a6d4-4d85-431b-9718-b10c7314c7b4
Apr 5 09:59:27 ocloud python: SELinux is preventing httpd from write access on the directory data.#012#012***** Plugin catchall_labels (83.8 confidence) suggests **************#012#012If you want to allow httpd to have write access on the data directory#012Then you need to change the label on data#012Do#012# semanage fcontext -a -t FILE_TYPE ‘data’#012where FILE_TYPE is one of the following: abrt_retrace_spool_t, apcupsd_cgi_ra_content_t, apcupsd_cgi_rw_content_t, awstats_ra_content_t, awstats_rw_content_t, bugzilla_ra_content_t, bugzilla_rw_content_t, cert_t, cifs_t, collectd_ra_content_t, collectd_rw_content_t, cvs_ra_content_t, cvs_rw_content_t, dirsrv_config_t, dirsrv_var_log_t, dirsrv_var_run_t, dirsrvadmin_config_t, dirsrvadmin_ra_content_t, dirsrvadmin_rw_content_t, dirsrvadmin_tmp_t, dspam_ra_content_t, dspam_rw_content_t, git_ra_content_t, git_rw_content_t, httpd_cache_t, httpd_log_t, httpd_squirrelmail_t, httpd_sys_content_t, httpd_sys_ra_content_t, httpd_sys_rw_content_t, httpd_tmp_t, httpd_tmpfs_t, httpd_user_content_t, httpd_user_ra_content_t, httpd_user_rw_content_t, httpd_var_lib_t, httpd_var_run_t, ipa_cert_t, ipa_var_run_t, jetty_cache_t, jetty_log_t, jetty_var_lib_t, jetty_var_run_t, keystone_cgi_ra_content_t, keystone_cgi_rw_content_t, krb5_host_rcache_t, man2html_ra_content_t, man2html_rw_content_t, mediawiki_ra_content_t, mediawiki_rw_content_t, mediawiki_tmp_t, mirrormanager_var_run_t, mojomojo_ra_content_t, mojomojo_rw_content_t, munin_ra_content_t, munin_rw_content_t, mythtv_ra_content_t, mythtv_rw_content_t, nagios_ra_content_t, nagios_rw_content_t, nutups_cgi_ra_content_t, nutups_cgi_rw_content_t, openshift_ra_content_t, openshift_rw_content_t, passenger_tmp_t, passenger_var_run_t, pki_ra_etc_rw_t, pki_ra_log_t, pki_ra_var_lib_t, pki_tps_etc_rw_t, pki_tps_log_t, pki_tps_var_lib_t, prewikka_ra_content_t, prewikka_rw_content_t, smokeping_cgi_ra_content_t, smokeping_cgi_rw_content_t, squid_ra_content_t, squid_rw_content_t, squirrelmail_spool_t, systemd_passwd_var_run_t, tmp_t, tmpfs_t, user_tmp_t, var_lib_t, var_lock_t, var_log_t, var_run_t, var_t, w3c_validator_ra_content_t, w3c_validator_rw_content_t, webalizer_ra_content_t, webalizer_rw_content_t, zarafa_var_lib_t, zoneminder_ra_content_t, zoneminder_rw_content_t, zoneminder_var_lib_t.#012Then execute:#012restorecon -v ‘data’#012#012#012 Plugin catchall (17.1 confidence) suggests **************************#012#012If you believe that httpd should be allowed write access on the data directory by default.#012Then you should report this as a bug.#012You can generate a local policy module to allow this access.#012Do#012allow this access for now by executing:#012# ausearch -c ‘httpd’ --raw | audit2allow -M my-httpd#012# semodule -i my-httpd.pp#012
And
[root@ocloud /]# sealert -l 50a3a6d4-4d85-431b-9718-b10c7314c7b4
***** Plugin catchall_labels (83.8 confidence) suggests *******************
Then l’étiquette sur data doit être modifiée.
Do
où FILE_TYPE est l’une des valeurs suivantes : abrt_retrace_spool_t, apcupsd_cgi_ra_content_t, apcupsd_cgi_rw_content_t, awstats_ra_content_t, awstats_rw_content_t, bugzilla_ra_content_t, bugzilla_rw_content_t, cert_t, cifs_t, collectd_ra_content_t, collectd_rw_content_t, cvs_ra_content_t, cvs_rw_content_t, dirsrv_config_t, dirsrv_var_log_t, dirsrv_var_run_t, dirsrvadmin_config_t, dirsrvadmin_ra_content_t, dirsrvadmin_rw_content_t, dirsrvadmin_tmp_t, dspam_ra_content_t, dspam_rw_content_t, git_ra_content_t, git_rw_content_t, httpd_cache_t, httpd_log_t, httpd_squirrelmail_t, httpd_sys_content_t, httpd_sys_ra_content_t, httpd_sys_rw_content_t, httpd_tmp_t, httpd_tmpfs_t, httpd_user_content_t, httpd_user_ra_content_t, httpd_user_rw_content_t, httpd_var_lib_t, httpd_var_run_t, ipa_cert_t, ipa_var_run_t, jetty_cache_t, jetty_log_t, jetty_var_lib_t, jetty_var_run_t, keystone_cgi_ra_content_t, keystone_cgi_rw_content_t, krb5_host_rcache_t, man2html_ra_content_t, man2html_rw_content_t, mediawiki_ra_content_t, mediawiki_rw_content_t, mediawiki_tmp_t, mirrormanager_var_run_t, mojomojo_ra_content_t, mojomojo_rw_content_t, munin_ra_content_t, munin_rw_content_t, mythtv_ra_content_t, mythtv_rw_content_t, nagios_ra_content_t, nagios_rw_content_t, nutups_cgi_ra_content_t, nutups_cgi_rw_content_t, openshift_ra_content_t, openshift_rw_content_t, passenger_tmp_t, passenger_var_run_t, pki_ra_etc_rw_t, pki_ra_log_t, pki_ra_var_lib_t, pki_tps_etc_rw_t, pki_tps_log_t, pki_tps_var_lib_t, prewikka_ra_content_t, prewikka_rw_content_t, smokeping_cgi_ra_content_t, smokeping_cgi_rw_content_t, squid_ra_content_t, squid_rw_content_t, squirrelmail_spool_t, systemd_passwd_var_run_t, tmp_t, tmpfs_t, user_tmp_t, var_lib_t, var_lock_t, var_log_t, var_run_t, var_t, w3c_validator_ra_content_t, w3c_validator_rw_content_t, webalizer_ra_content_t, webalizer_rw_content_t, zarafa_var_lib_t, zoneminder_ra_content_t, zoneminder_rw_content_t, zoneminder_var_lib_t.
Puis exécutez :
***** Plugin catchall (17.1 confidence) suggests **************************
If vous pensez que httpd devrait être autorisé à accéder write sur data directory par défaut.
Then vous devriez rapporter ceci en tant qu’anomalie.
Vous pouvez générer un module de stratégie local pour autoriser cet accès.
Do
Additional Information:
Source Context system_u:system_r:httpd_t:s0
Target Context unconfined_u:object_r:unlabeled_t:s0
Target Objects data [ dir ]
Source httpd
Source Path httpd
Port
Host ocloud
Source RPM Packages
Target RPM Packages
Policy RPM selinux-policy-3.13.1-166.el7_4.7.noarch
Selinux Enabled True
Policy Type targeted
Enforcing Mode Enforcing
Host Name ocloud
Platform Linux ocloud
3.10.0-693.11.6.el7.x86_64 #1 SMP Thu Jan 4
01:06:37 UTC 2018 x86_64 x86_64
Alert Count 19
First Seen 2018-04-05 09:30:57 CEST
Last Seen 2018-04-05 10:01:17 CEST
Local ID 50a3a6d4-4d85-431b-9718-b10c7314c7b4
Raw Audit Messages
type=AVC msg=audit(1522915277.192:225): avc: denied { write } for pid=11888 comm=“httpd” name=“data” dev=“sdb1” ino=5701633 scontext=system_u:system_r:httpd_t:s0 tcontext=unconfined_u:object_r:unlabeled_t:s0 tclass=dir
Hash: httpd,httpd_t,unlabeled_t,dir,write
Can you have a look in the owncloud.log?
It should be in your data directory
The owncloud.log is enpty, apache can’t write.
If SELinux is the issue then i think you can try to disable it temporary:
If that works and ownCloud can write into it again then you probably need to find some one helping you to correct the SELinux rules like e.g. suggested here:
Thanks Tom42
After “setenforce 0” I can again acces on my owncloud.
Where I can find the log of selinux ?
I think for such questions you should have a look at the manual / man pages of your linux distro. Those doesn’t look like related to ownCloud.
I try :
chcon -t httpd_sys_rw_content_t /media/odata -R
and “setenforce 1”. and it’s working !!!
But the Ldap authentification doen’t work !
I don’t think that it is advised to start with a new problem in the same thread.
Doesn’t work is something which i think is also no good issue description.
