Hello folks,
I’m really struggling with a files not found problem with owncloud 10. It is installed in /var/www/owncloud and reachable at v.niceserv.de/owncloud. The setup pages worked fine and owncloud got setup successfully (data folders in place, db user setup, …). Yet, after those 2 pages owncloud is not displayed, instead I receive the 404 page. The interesting part is that it tries to load all .js and .css files of owncloud but fails for all of them with a 404 file not found. I checked the fastcgi_params and they look ok. The config is based on the config of the documentation.
Is there anyone out there that can help me?
- Full purge of owncloud-files, nginx, mysql and php5 after unsolvable problems
- Setup-page worked, but css and js files were not found
- After adapting the root folder in the nginx config, the setup page worked and I was able to install owncloud
- No files are found anymore
Owncloud files found and working.
I can only see the 404 page of owncloud after setup was successfully done. The config nor the permissions of the owncloud folder were not changed after setup.
Debian Jessie (3.16.0-4-amd64 #1 SMP Debian 3.16.43-2+deb8u5 (2017-09-19) x86_64 )
Nginx 1.13.8
mysql Ver 14.14 Distrib 5.5.59, for debian-linux-gnu (x86_64) using readline 6.3
PHP 5PHP 5.6.33-0+deb8u1 (cli)
ownCloud version:
10.0.4.4
Fresh install
Repository
No login possible
"system": {
"updatechecker": false,
"instanceid": "123",
"overwritewebroot": "\/owncloud",
"trusted_domains": [
"v.nicesrv.de"
"datadirectory": "\/var\/oc_data",
"overwrite.cli.url": "https:\/\/v.nicesrv.de\/owncloud",
"dbtype": "mysql",
"version": "10.0.4.4",
"dbname": "cloud",
"dbhost": "localhost",
"dbtableprefix": "oc_",
"logtimezone": "UTC",
"installed": true
Enabled:
- comments: 0.3.0
- configreport: 0.1.1
- dav: 0.3.2
- federatedfilesharing: 0.3.1
- federation: 0.1.0
- files: 1.5.1
- files_external: 0.7.1
- files_sharing: 0.10.1
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- files_videoplayer: 0.9.8
- firstrunwizard: 1.1
- market: 0.2.3
- notifications: 0.3.2
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- templateeditor: 0.1
- updatenotification: 0.2.1
Disabled:
- encryption
- external
- theme-example
- user_external
No
No
No
Firefox 57.0.3 (64-Bit)
Ubuntu 17.10
2018/01/22 15:05:18 [error] 444#444: *2212 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: 88.217.181.181, server: v.nicesrv.de, request: "GET /owncloud/core/js/mimetype.js?v=f23b49e0391ed08afeebaa748ed4956f HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "v.nicesrv.de"
2018/01/22 15:05:18 [error] 444#444: *2210 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: 88.217.181.181, server: v.nicesrv.de, request: "GET /owncloud/core/js/mimetypelist.js?v=f23b49e0391ed08afeebaa748ed4956f HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "v.nicesrv.de"
2018/01/22 15:05:18 [error] 444#444: *2211 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: 88.217.181.181, server: v.nicesrv.de, request: "GET /owncloud/core/vendor/snapjs/dist/latest/snap.js?v=f23b49e0391ed08afeebaa748ed4956f HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "v.nicesrv.de"
2018/01/22 15:05:18 [error] 444#444: *2213 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: 88.217.181.181, server: v.nicesrv.de, request: "GET /owncloud/core/js/oc-backbone.js?v=f23b49e0391ed08afeebaa748ed4956f HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "v.nicesrv.de"
2018/01/22 15:05:18 [error] 444#444: *2214 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: 88.217.181.181, server: v.nicesrv.de, request: "GET /owncloud/core/js/placeholder.js?v=f23b49e0391ed08afeebaa748ed4956f HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "v.nicesrv.de"
2018/01/22 15:05:18 [error] 444#444: *2202 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: 88.217.181.181, server: v.nicesrv.de, request: "GET /owncloud/core/js/jquery.avatar.js?v=f23b49e0391ed08afeebaa748ed4956f HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "v.nicesrv.de"
2018/01/22 15:05:18 [error] 444#444: *2212 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: 88.217.181.181, server: v.nicesrv.de, request: "GET /owncloud/core/js/backgroundjobs.js?v=f23b49e0391ed08afeebaa748ed4956f HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "v.nicesrv.de"
2018/01/22 15:05:18 [error] 444#444: *2210 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: 88.217.181.181, server: v.nicesrv.de, request: "GET /owncloud/core/js/files/fileinfo.js?v=f23b49e0391ed08afeebaa748ed4956f HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "v.nicesrv.de"
2018/01/22 15:05:18 [error] 444#444: *2211 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: 88.217.181.181, server: v.nicesrv.de, request: "GET /owncloud/core/js/files/client.js?v=f23b49e0391ed08afeebaa748ed4956f HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "v.nicesrv.de"
empty
Example answer header:
Cache-Control | no-store, no-cache, must-reval…te, post-check=0, pre-check=0
Connection | keep-alive
Content-Security-Policy | default-src 'self'; script-src…:; media-src *; connect-src *
Content-Type | text/html; charset=UTF-8
Date | Mon, 22 Jan 2018 14:05:16 GMT
Expires | Thu, 19 Nov 1981 08:52:00 GMT
Pragma | no-cache
Server | nginx/1.13.8
Transfer-Encoding | chunked
Example request header:
Accept | text/html,application/xhtml+xm…plication/xml;q=0.9,*/*;q=0.8
Accept-Encoding | gzip, deflate, br
Accept-Language | de,en-US;q=0.7,en;q=0.3
Cache-Control | max-age=0
Cookie | ocllja27193p=7ilglqmsnhtr0v2i4…E0OiiKnW9y4KSTMi5m59lUIyQanHx
DNT | 1
Host | v.nicesrv.de
Upgrade-Insecure-Requests | 1
User-Agent | Mozilla/5.0 (X11; Ubuntu; Linu…) Gecko/20100101 Firefox/57.0
Configs
nginx.conf
user www-data; #nginx;
worker_processes 2;
error_log /var/log/nginx/error.log warn;
pid /var/run/nginx.pid;
events {
worker_connections 1024;
http {
include mime.types;
default_type application/octet-stream;
log_format main '$remote_addr - $remote_user [$time_local] "$request" '
'$status $body_bytes_sent "$http_referer" '
'"$http_user_agent" "$http_x_forwarded_for"';
log_format scripts '$document_root > $fastcgi_script_name > $request';
access_log /var/log/nginx/access.log main;
sendfile on;
#tcp_nopush on;
keepalive_timeout 65;
#gzip on;
include /etc/nginx/conf.d/*.conf;
cloud.conf in conf.d folder
upstream php-handler {
#server 127.0.0.1:9000;
# Depending on your used PHP version
server unix:/var/run/php5-fpm.sock;
#server unix:/var/run/php7-fpm.sock;
server {
listen 80;
server_name v.nicesrv.de;
# For Lets Encrypt, this needs to be served via HTTP
location /.well-known/acme-challenge/ {
root /var/www/owncloud; # Specify here where the challenge file is placed
# enforce https
location / {
return 301 https://$server_name$request_uri;
server {
listen 443 ssl http2;
ssl_certificate /etc/letsencrypt/live/v.nicesrv.de/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/v.nicesrv.de/privkey.pem;
# Example SSL/TLS configuration. Please read into the manual of
# nginx before applying these.
ssl_session_timeout 5m;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
ssl_ciphers "-ALL:EECDH+AES256:EDH+AES256:AES256-SHA:EECDH+AES:EDH+AES:!ADH:!NULL:!aNULL:!eNULL:!EXPORT:!LOW:!MD5:!3DES:!PSK:!SRP:!DSS:!AESGCM:!RC4";
ssl_dhparam /etc/letsencrypt/diffie-hellman/dhparam4096.pem;
ssl_prefer_server_ciphers on;
keepalive_timeout 70;
ssl_stapling on;
ssl_stapling_verify on;
# Add headers to serve security related headers
# Before enabling Strict-Transport-Security headers please read into this topic first.
#add_header Strict-Transport-Security "max-age=15552000; includeSubDomains";
add_header X-Content-Type-Options nosniff;
add_header X-Frame-Options "SAMEORIGIN";
add_header X-XSS-Protection "1; mode=block";
add_header X-Robots-Tag none;
add_header X-Download-Options noopen;
add_header X-Permitted-Cross-Domain-Policies none;
add_header Z-SCRIPT_FILENAME $document_root$fastcgi_script_name;
add_header Z-ROOT $document_root;
add_header Z-SCRIPT_NAME $fastcgi_script_name; # necessary for owncloud to detect the contextr$
add_header Z-PATH_INFO $fastcgi_path_info;
add_header Z-URI $uri;
add_header Z-REQUEST_URI $request_uri;
add_header Z-QUERY_STRING $query_string;
add_header Z-REQUEST_METHOD $request_method;
# Path to the root of your installation
root /var/www/;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
location = /.well-known/carddav {
return 301 $scheme://$host/owncloud/remote.php/dav;
location = /.well-known/caldav {
location ^~ /owncloud {
access_log /var/log/nginx/scripts.log scripts;
root /var/www/; #owncloud/;
# set max upload size
client_max_body_size 512M;
fastcgi_buffers 8 4K; # Please see note 1
fastcgi_ignore_headers X-Accel-Buffering; # Please see note 2
# Disable gzip to avoid the removal of the ETag header
# Enabling gzip would also make your server vulnerable to BREACH
# if no additional measures are done. See https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=773332
gzip off;
error_page 403 /owncloud/core/templates/403.php;
error_page 404 /owncloud/core/templates/404.php;
location /owncloud {
rewrite ^ /owncloud/index.php$uri;
location ~ ^/owncloud/(?:build|tests|config|lib|3rdparty|templates|data)/ {
return 404;
location ~ ^/owncloud/(?:\.|autotest|occ|issue|indie|db_|console) {
return 404;
location ~ ^/owncloud/(?:index|remote|public|cron|core/ajax/update|status|ocs/v[12]|updater/.+|ocs-provider/.+|core/templates/40[34])\.php(?:$|/) {
fastcgi_split_path_info ^/owncloud(.+\.php)(/.*)$;
include fastcgi_params;
fastcgi_param SCRIPT_NAME $fastcgi_script_name; # necessary for owncloud to detect the contextroot https://github.com/owncloud/core/blob/v10.0.$
fastcgi_param PATH_INFO $fastcgi_path_info;
fastcgi_param HTTPS on;
fastcgi_param modHeadersAvailable true; #Avoid sending the security headers twice
# EXPERIMENTAL: active the following if you need to get rid of the 'index.php' in the URLs
#fastcgi_param front_controller_active true;
fastcgi_read_timeout 180; # increase default timeout e.g. for long running carddav/ caldav syncs with 1000+ entries
fastcgi_pass php-handler;
fastcgi_intercept_errors on;
fastcgi_request_buffering off; #Available since NGINX 1.7.11
location ~ ^/owncloud/(?:updater|ocs-provider)(?:$|/) {
try_files $uri $uri/ =404;
index index.php;
# Adding the cache control header for js and css files
# Make sure it is BELOW the PHP block
location ~ /owncloud(\/.*\.(?:css|js)) {
try_files $1 /owncloud/index.php$1$is_args$args;
add_header Cache-Control "max-age=15778463";
# Add headers to serve security related headers (It is intended to have those duplicated to the ones above)
# Optional: Don't log access to assets
access_log on; #off;
location ~ /owncloud(/.*\.(?:svg|gif|png|html|ttf|woff|ico|jpg|jpeg|map)) {
add_header Cache-Control "public, max-age=7200";
# Optional: Don't log access to other assets
access_log off;
Folder permissions of owncloud directory
-rw-r----- 1 root www-data 8859 Dec 5 17:14 AUTHORS
-rw-r----- 1 root www-data 36228 Dec 5 17:14 CHANGELOG.md
-rw-r----- 1 root www-data 34520 Dec 5 17:14 COPYING
drwxr-x--- 24 www-data www-data 4096 Jan 7 14:11 apps
drwxr-x--- 2 root www-data 4096 Dec 5 20:52 assets
drwxr-x--- 2 www-data www-data 4096 Jan 7 14:12 config
-rw-r----- 1 root www-data 4345 Dec 5 17:14 console.php
drwxr-x--- 17 root www-data 4096 Jan 7 14:11 core
-rw-r----- 1 root www-data 4969 Dec 5 17:14 cron.php
drwxr-x--- 2 root www-data 4096 Jan 7 14:12 data
-rw-r----- 1 root www-data 30898 Dec 5 17:14 db_structure.xml
drwxr-x--- 2 root www-data 4096 Dec 5 20:52 etc
-rw-r----- 1 root www-data 179 Dec 5 17:14 index.html
-rw-r----- 1 root www-data 3898 Dec 5 17:14 index.php
drwxr-x--- 3 root www-data 4096 Jan 7 14:11 l10n
drwxr-x--- 6 root www-data 4096 Jan 7 14:11 lib
-rwxr-x--x 1 root www-data 283 Dec 5 17:14 occ
drwxr-x--- 2 root www-data 4096 Jan 7 14:11 ocs
drwxr-x--- 2 root www-data 4096 Jan 7 14:11 ocs-provider
-rw-r----- 1 root www-data 3197 Dec 5 17:14 public.php
-rw-r----- 1 root www-data 5481 Dec 5 17:14 remote.php
drwxr-x--- 4 root www-data 4096 Jan 7 14:10 resources
drwxr-x--- 12 root www-data 4096 Jan 7 14:11 settings
-rw-r----- 1 root www-data 1884 Dec 5 17:14 status.php
drwxr-x--- 6 www-data www-data 4096 Jan 7 14:11 updater
-rw-r----- 1 root www-data 271 Dec 5 17:16 version.php
