Hi @cortho,
I upgraded the owncloud from 10.3.0 to the latest version 10.11 but it shows the same issue about the 404 Not Found page. So, I thought due to the huge version gap. I try to upgrade the owncloud 10.3.0 to 10.3.2. It still shows the error while redirecting to the login page.
- Update page is working, after updating it will redirect to the login page and shows 404 Not Found.
Expected behavior
It should show the login page after the update. The permission of the file are ok.
Actual behavior
Show 404 Not Found “nginx”
Server configurationPreformatted text
Operating system :
Ngnix 1.21.6
MySQL 10.11.0.6
ownCloud 10.3.0
update from an older ownCloud.
from owncloud server packages.
No login possible
<?php
$CONFIG = array (
'instanceid' => '*****',
'passwordsalt' => '*****',
'secret' => '*****',
'trusted_domains' =>
array (
0 => '*****',
'datadirectory' => '/****/****/****/****/owncloud-data',
'overwrite.cli.url' => 'http://****',
'dbtype' => 'mysql',
'version' => '10.11.0.6',
'dbname' => '****',
'dbhost' => 'localhost',
'dbtableprefix' => 'oc_',
'mysql.utf8mb4' => true,
'dbuser' => '****',
'dbpassword' => '****',
'logtimezone' => 'UTC',
'apps_paths' =>
array (
0 =>
array (
'path' => '/****/****/****/***/****/owncloud/apps',
'url' => '/apps',
'writable' => false,
1 =>
array (
'path' => '/***/***/*****/***/****/owncloud/apps-external',
'url' => '/apps-external',
'writable' => true,
'installed' => true,
'theme' => '',
'loglevel' => 2,
'maintenance' => false,
Admin is not working and sudo command is also not working.
No
No
No
Chrome Version 107.0.5304.107 (64-bit)
Window 10
empty
on crash.log file
"date": "2022-11-11T13:13:40+01:00",
"parentId": null,
"id": "****",
"class": "ParseError",
"message": "syntax error, unexpected ','",
"stacktrace": [
"file": "\/****\/****\/****\/****\/****\/***\/***\/******\/owncloud\/lib\/private\/Config.php",
"line": 64,
"function": "readData",
"class": "OC\\Config"
"file": "\/****\/****\/****\/****\/****\/***\/***\/******\/owncloud\/lib\/base.php",
"line": 135,
"function": "__construct",
"line": 531,
"function": "initPaths",
"class": "OC"
"line": 1060,
"function": "init",
"class": "OC"
"file": "\/****\/****\/****\/****\/****\/***\/***\/******\/owncloud\/index.php",
"line": 53,
"function": "require_once"
"parentId": null,
"id": "****",
"class": "Error",
"message": "Call to a member function getLogger() on null",
"stacktrace": []
"date": "2022-11-11T13:13:43+01:00",
"parentId": null,
"id": "****",
"stacktrace": [
"line": 64,
"line": 135,
"line": 531,
"class": "OC"
"line": 1060,
"function": "init",
"class": "OC"
"line": 53,
"parentId": null,
"id": "*****",
"class": "Error",
"stacktrace": []
"date": "2022-11-11T13:13:44+01:00",
"parentId": null,
"id": "*****",
"stacktrace": [
"line": 64,
"line": 135,
"line": 531,
"class": "OC"
"line": 1060,
"function": "init",
"class": "OC"
"line": 53,
"parentId": null,
"id": "*****",
"class": "Error",
"stacktrace": []
"parentId": null,
"id": "*****",
"stacktrace": [
"line": 64,
"line": 135,
"line": 531,
"class": "OC"
"line": 1060,
"function": "init",
"class": "OC"
"line": 53,
"parentId": null,
"id": "*****",
"class": "Error",
"stacktrace": []
"date": "2022-11-11T13:13:45+01:00",
"parentId": null,
"id": "*****",
"stacktrace": [
"line": 64,
"line": 135,
"line": 531,
"class": "OC"
"line": 1060,
"function": "init",
"class": "OC"
"line": 53,
"parentId": null,
"id": "*****",
"class": "Error",
"stacktrace": []
"date": "2022-11-11T13:13:46+01:00",
"parentId": null,
"id": "******",
"stacktrace": [
"line": 64,
"file": "\/****\/****\/****\/****\/****\/***\/***\/******/owncloud\/lib\/base.php",
"line": 135,
"line": 531,
"class": "OC"
"line": 1060,
"function": "init",
"class": "OC"
"line": 53,
"parentId": null,
"id": "*****",
"class": "Error",
"stacktrace": []
"date": "2022-11-11T13:13:47+01:00",
"parentId": null,
"id": "******",
"stacktrace": [
"line": 64,
"file": "\/****\/****\/****\/****\/****\/***\/***\/******\/lib\/base.php",
"line": 135,
"file": "\/***\/***\/***\/***\/***\/***\/***\/owncloud\/lib\/base.php",
"line": 531,
"class": "OC"
"file": "\/****\/****\/***\/****\/****\/***\/***\/owncloud\/lib\/base.php",
"line": 1060,
"function": "init",
"class": "OC"
"file": "\/****\/***\/****\/****\/***\/***\/***\/owncloud\/index.php",
"line": 53,
"parentId": null,
"id": "****",
"class": "Error",
"stacktrace": []
While upgrading through cmd ./occ upgrade shows an error msg.
Doctrine\DBAL\DBALException: Failed to connect to the database: An exception occured in driver: SQLSTATE[HY000] [2002] No such file or directory in /web/owncloud/lib/private/DB/Connection.php:62
Stack trace:
#0 /web/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(429): OC\DB\Connection->connect()
#1 /web/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(389): Doctrine\DBAL\Connection->getDatabasePlatformVersion()
#2 /web/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(328): Doctrine\DBAL\Connection->detectDatabasePlatform()
#3 /web/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(623): Doctrine\DBAL\Connection->getDatabasePlatform()
#4 /web/owncloud/lib/private/DB/Connection.php(144): Doctrine\DBAL\Connection->setTransactionIsolation(2)
#5 /web/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(172): OC\DB\Connection->__construct(Array, Object(Doctrine\DBAL\Driver\PDOMySql\Driver), Object(Doctrine\DBAL\Configuration), Object(Doctrine\Common\EventManager))
#6 /web/owncloud/lib/private/DB/ConnectionFactory.php(143): Doctrine\DBAL\DriverManager::getConnection(Array, Object(Doctrine\DBAL\Configuration), Object(Doctrine\Common\EventManager))
#7 /web/owncloud/lib/private/Server.php(532): OC\DB\ConnectionFactory->getConnection('mysql', Array)
#8 /web/owncloud/lib/composer/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC\{closure}(Object(OC\Server))
#9 /web/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(108): Pimple\Container->offsetGet('DatabaseConnect...')
#10 /web/owncloud/lib/private/ServerContainer.php(86): OC\AppFramework\Utility\SimpleContainer->query('DatabaseConnect...')
#11 /web/owncloud/lib/private/Server.php(1220): OC\ServerContainer->query('DatabaseConnect...')
#12 /web/owncloud/lib/private/Server.php(406): OC\Server->getDatabaseConnection()
#13 /web/owncloud/lib/composer/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC\{closure}(Object(OC\Server))
#14 /web/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(108): Pimple\Container->offsetGet('AppConfig')
#15 /web/owncloud/lib/private/ServerContainer.php(86): OC\AppFramework\Utility\SimpleContainer->query('AppConfig')
#16 /web/owncloud/lib/private/Server.php(1150): OC\ServerContainer->query('AppConfig')
#17 /web/owncloud/lib/private/Server.php(587): OC\Server->getAppConfig()
#18 /web/owncloud/lib/composer/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC\{closure}(Object(OC\Server))
#19 /web/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(108): Pimple\Container->offsetGet('AppManager')
#20 /web/owncloud/lib/private/ServerContainer.php(86): OC\AppFramework\Utility\SimpleContainer->query('AppManager')
#21 /web/owncloud/lib/private/Server.php(1418): OC\ServerContainer->query('AppManager')
#22 /web/owncloud/lib/private/legacy/app.php(343): OC\Server->getAppManager()
#23 /web/owncloud/lib/private/legacy/app.php(107): OC_App::getEnabledApps()
#24 /web/owncloud/lib/base.php(585): OC_App::loadApps(Array)
#25 /web/owncloud/lib/base.php(1005): OC::init()
#26 /web/owncloud/console.php(64): require_once('/web/owncloud/l...')
#27 /web/owncloud/occ(11): require_once('/web/owncloud/c...')
