9.0.4 patch doesn't work for me
  1. Apply patch from here;
  2. Restart the server;
  3. Bump into error on the update page.
Update to 9.0.5
  1. Core inegrity check fails;
  2. ee[GuzzleHttp\Exception\RequestException] e e cURL error 51: SSL: no alternative certificate subject name matches target host name 'localhost' e
Operating system: Ubuntu 16.04.1 LTS
Web server: Caddy 0.8.3
Database: PostgreSQL 9.6.1
PHP version: 7.0.8 (system default)
ownCloud version (see ownCloud admin page): 9.0.4
Updated from an older ownCloud or fresh install: updated from 9.0.2, 9.0.2 - clean install
Special configuration: external ftp
{"reqId":"4dc1kXsAcn5VRV0fWoC2","remoteAddr":"","app":"PHP","message":"Error: Call to a member function getPath() on null at \/etc\/caddy\/site\/owncloud\/lib\/private\/files\/filesystem.php#911","level":3,"time":"2016-10-28T12:45:02+00:00","method":"--","url":"--","user":"--"}
{"reqId":"KVGOFq1EInDwEA52MyxK","remoteAddr":"128.68.54.107","app":"PHP","message":"OCP\\AutoloadNotAllowedException: Autoload path not allowed: \/etc\/caddy\/site\/owncloud\/apps\/dav\/lib\/connector\/sabre\/exceptionloggerplugin.php at \/etc\/caddy\/site\/owncloud\/lib\/autoloader.php#152","level":3,"time":"2016-10-28T13:32:35+00:00","method":"PROPFIND","url":"\/remote.php\/webdav\/","user":"--"}
{"reqId":"8EoAnYbUXVIvp2kpf8Kd","remoteAddr":"128.68.54.107","app":"PHP","message":"OCP\\AutoloadNotAllowedException: Autoload path not allowed: \/etc\/caddy\/site\/owncloud\/apps\/dav\/lib\/connector\/sabre\/exceptionloggerplugin.php at \/etc\/caddy\/site\/owncloud\/lib\/autoloader.php#152","level":3,"time":"2016-10-28T13:32:48+00:00","method":"PROPFIND","url":"\/remote.php\/webdav\/","user":"--"}
{"reqId":"toCmnq1\/XHoVCyn0qgoI","remoteAddr":"193.124.178.6","app":"index","message":"Exception: {\"Exception\":\"OCP\\\\AppFramework\\\\QueryException\",\"Message\":\"Could not resolve OCA\\\\Core\\\\Controller\\\\OccController! Class OCA\\\\Core\\\\Controller\\\\OccController does not exist\",\"Code\":0,\"Trace\":\"#0 \\\/etc\\\/caddy\\\/site\\\/owncloud\\\/lib\\\/private\\\/appframework\\\/utility\\\/simplecontainer.php(104): OC\\\\AppFramework\\\\Utility\\\\SimpleContainer->resolve('OCA\\\\\\\\Core\\\\\\\\Contro...')\\n#1 \\\/etc\\\/caddy\\\/site\\\/owncloud\\\/lib\\\/private\\\/appframework\\\/app.php(97): OC\\\\AppFramework\\\\Utility\\\\SimpleContainer->query('OCA\\\\\\\\Core\\\\\\\\Contro...')\\n#2 \\\/etc\\\/caddy\\\/site\\\/owncloud\\\/lib\\\/private\\\/appframework\\\/routing\\\/routeactionhandler.php(45): OC\\\\AppFramework\\\\App::main('OCA\\\\\\\\Core\\\\\\\\Contro...', 'execute', Object(OC\\\\AppFramework\\\\DependencyInjection\\\\DIContainer), Array)\\n#3 [internal function]: OC\\\\AppFramework\\\\routing\\\\RouteActionHandler->__invoke(Array)\\n#4 \\\/etc\\\/caddy\\\/site\\\/owncloud\\\/lib\\\/private\\\/route\\\/router.php(276): call_user_func(Object(OC\\\\AppFramework\\\\routing\\\\RouteActionHandler), Array)\\n#5 \\\/etc\\\/caddy\\\/site\\\/owncloud\\\/lib\\\/base.php(907): OC\\\\Route\\\\Router->match('\\\/occ\\\/config:lis...')\\n#6 \\\/etc\\\/caddy\\\/site\\\/owncloud\\\/index.php(39): OC::handleRequest()\\n#7 {main}\",\"File\":\"\\\/etc\\\/caddy\\\/site\\\/owncloud\\\/lib\\\/private\\\/appframework\\\/utility\\\/simplecontainer.php\",\"Line\":89}","level":3,"time":"2016-10-28T15:08:06+00:00","method":"POST","url":"\/index.php\/occ\/config:list","user":"--"}
{"reqId":"3OydQdy8nVQtWkAzuXxt","remoteAddr":"193.124.178.6","app":"index","message":"Exception: {\"Exception\":\"OCP\\\\AppFramework\\\\QueryException\",\"Message\":\"Could not resolve OCA\\\\Core\\\\Controller\\\\OccController! Class OCA\\\\Core\\\\Controller\\\\OccController does not exist\",\"Code\":0,\"Trace\":\"#0 \\\/etc\\\/caddy\\\/site\\\/owncloud\\\/lib\\\/private\\\/appframework\\\/utility\\\/simplecontainer.php(104): OC\\\\AppFramework\\\\Utility\\\\SimpleContainer->resolve('OCA\\\\\\\\Core\\\\\\\\Contro...')\\n#1 \\\/etc\\\/caddy\\\/site\\\/owncloud\\\/lib\\\/private\\\/appframework\\\/app.php(97): OC\\\\AppFramework\\\\Utility\\\\SimpleContainer->query('OCA\\\\\\\\Core\\\\\\\\Contro...')\\n#2 \\\/etc\\\/caddy\\\/site\\\/owncloud\\\/lib\\\/private\\\/appframework\\\/routing\\\/routeactionhandler.php(45): OC\\\\AppFramework\\\\App::main('OCA\\\\\\\\Core\\\\\\\\Contro...', 'execute', Object(OC\\\\AppFramework\\\\DependencyInjection\\\\DIContainer), Array)\\n#3 [internal function]: OC\\\\AppFramework\\\\routing\\\\RouteActionHandler->__invoke(Array)\\n#4 \\\/etc\\\/caddy\\\/site\\\/owncloud\\\/lib\\\/private\\\/route\\\/router.php(276): call_user_func(Object(OC\\\\AppFramework\\\\routing\\\\RouteActionHandler), Array)\\n#5 \\\/etc\\\/caddy\\\/site\\\/owncloud\\\/lib\\\/base.php(907): OC\\\\Route\\\\Router->match('\\\/occ\\\/config:lis...')\\n#6 \\\/etc\\\/caddy\\\/site\\\/owncloud\\\/index.php(39): OC::handleRequest()\\n#7 {main}\",\"File\":\"\\\/etc\\\/caddy\\\/site\\\/owncloud\\\/lib\\\/private\\\/appframework\\\/utility\\\/simplecontainer.php\",\"Line\":89}","level":3,"time":"2016-10-28T15:08:09+00:00","method":"POST","url":"\/index.php\/occ\/config:list","user":"--"}
{"reqId":"zvdOCgQIUCPc2FJ7mOqW","remoteAddr":"193.124.178.6","app":"index","message":"Exception: {\"Exception\":\"OCP\\\\AppFramework\\\\QueryException\",\"Message\":\"Could not resolve OCA\\\\Core\\\\Controller\\\\OccController! Class OCA\\\\Core\\\\Controller\\\\OccController does not exist\",\"Code\":0,\"Trace\":\"#0 \\\/etc\\\/caddy\\\/site\\\/owncloud\\\/lib\\\/private\\\/appframework\\\/utility\\\/simplecontainer.php(104): OC\\\\AppFramework\\\\Utility\\\\SimpleContainer->resolve('OCA\\\\\\\\Core\\\\\\\\Contro...')\\n#1 \\\/etc\\\/caddy\\\/site\\\/owncloud\\\/lib\\\/private\\\/appframework\\\/app.php(97): OC\\\\AppFramework\\\\Utility\\\\SimpleContainer->query('OCA\\\\\\\\Core\\\\\\\\Contro...')\\n#2 \\\/etc\\\/caddy\\\/site\\\/owncloud\\\/lib\\\/private\\\/appframework\\\/routing\\\/routeactionhandler.php(45): OC\\\\AppFramework\\\\App::main('OCA\\\\\\\\Core\\\\\\\\Contro...', 'execute', Object(OC\\\\AppFramework\\\\DependencyInjection\\\\DIContainer), Array)\\n#3 [internal function]: OC\\\\AppFramework\\\\routing\\\\RouteActionHandler->__invoke(Array)\\n#4 \\\/etc\\\/caddy\\\/site\\\/owncloud\\\/lib\\\/private\\\/route\\\/router.php(276): call_user_func(Object(OC\\\\AppFramework\\\\routing\\\\RouteActionHandler), Array)\\n#5 \\\/etc\\\/caddy\\\/site\\\/owncloud\\\/lib\\\/base.php(907): OC\\\\Route\\\\Router->match('\\\/occ\\\/config:lis...')\\n#6 \\\/etc\\\/caddy\\\/site\\\/owncloud\\\/index.php(39): OC::handleRequest()\\n#7 {main}\",\"File\":\"\\\/etc\\\/caddy\\\/site\\\/owncloud\\\/lib\\\/private\\\/appframework\\\/utility\\\/simplecontainer.php\",\"Line\":89}","level":3,"time":"2016-10-28T15:08:17+00:00","method":"POST","url":"\/index.php\/occ\/config:list","user":"--"}
{"reqId":"ksjEKbCz2B9Vz0ux+VHK","remoteAddr":"193.124.178.6","app":"index","message":"Exception: {\"Exception\":\"OCP\\\\AppFramework\\\\QueryException\",\"Message\":\"Could not resolve OCA\\\\Core\\\\Controller\\\\OccController! Class OCA\\\\Core\\\\Controller\\\\OccController does not exist\",\"Code\":0,\"Trace\":\"#0 \\\/etc\\\/caddy\\\/site\\\/owncloud\\\/lib\\\/private\\\/appframework\\\/utility\\\/simplecontainer.php(104): OC\\\\AppFramework\\\\Utility\\\\SimpleContainer->resolve('OCA\\\\\\\\Core\\\\\\\\Contro...')\\n#1 \\\/etc\\\/caddy\\\/site\\\/owncloud\\\/lib\\\/private\\\/appframework\\\/app.php(97): OC\\\\AppFramework\\\\Utility\\\\SimpleContainer->query('OCA\\\\\\\\Core\\\\\\\\Contro...')\\n#2 \\\/etc\\\/caddy\\\/site\\\/owncloud\\\/lib\\\/private\\\/appframework\\\/routing\\\/routeactionhandler.php(45): OC\\\\AppFramework\\\\App::main('OCA\\\\\\\\Core\\\\\\\\Contro...', 'execute', Object(OC\\\\AppFramework\\\\DependencyInjection\\\\DIContainer), Array)\\n#3 [internal function]: OC\\\\AppFramework\\\\routing\\\\RouteActionHandler->__invoke(Array)\\n#4 \\\/etc\\\/caddy\\\/site\\\/owncloud\\\/lib\\\/private\\\/route\\\/router.php(276): call_user_func(Object(OC\\\\AppFramework\\\\routing\\\\RouteActionHandler), Array)\\n#5 \\\/etc\\\/caddy\\\/site\\\/owncloud\\\/lib\\\/base.php(907): OC\\\\Route\\\\Router->match('\\\/occ\\\/config:lis...')\\n#6 \\\/etc\\\/caddy\\\/site\\\/owncloud\\\/index.php(39): OC::handleRequest()\\n#7 {main}\",\"File\":\"\\\/etc\\\/caddy\\\/site\\\/owncloud\\\/lib\\\/private\\\/appframework\\\/utility\\\/simplecontainer.php\",\"Line\":89}","level":3,"time":"2016-10-28T15:08:22+00:00","method":"POST","url":"\/index.php\/occ\/config:list","user":"--"}
{"reqId":"YOUbmLU0mx\/vTbRnTJEn","remoteAddr":"193.124.178.6","app":"index","message":"Exception: {\"Exception\":\"OCP\\\\AppFramework\\\\QueryException\",\"Message\":\"Could not resolve OCA\\\\Core\\\\Controller\\\\OccController! Class OCA\\\\Core\\\\Controller\\\\OccController does not exist\",\"Code\":0,\"Trace\":\"#0 \\\/etc\\\/caddy\\\/site\\\/owncloud\\\/lib\\\/private\\\/appframework\\\/utility\\\/simplecontainer.php(104): OC\\\\AppFramework\\\\Utility\\\\SimpleContainer->resolve('OCA\\\\\\\\Core\\\\\\\\Contro...')\\n#1 \\\/etc\\\/caddy\\\/site\\\/owncloud\\\/lib\\\/private\\\/appframework\\\/app.php(97): OC\\\\AppFramework\\\\Utility\\\\SimpleContainer->query('OCA\\\\\\\\Core\\\\\\\\Contro...')\\n#2 \\\/etc\\\/caddy\\\/site\\\/owncloud\\\/lib\\\/private\\\/appframework\\\/routing\\\/routeactionhandler.php(45): OC\\\\AppFramework\\\\App::main('OCA\\\\\\\\Core\\\\\\\\Contro...', 'execute', Object(OC\\\\AppFramework\\\\DependencyInjection\\\\DIContainer), Array)\\n#3 [internal function]: OC\\\\AppFramework\\\\routing\\\\RouteActionHandler->__invoke(Array)\\n#4 \\\/etc\\\/caddy\\\/site\\\/owncloud\\\/lib\\\/private\\\/route\\\/router.php(276): call_user_func(Object(OC\\\\AppFramework\\\\routing\\\\RouteActionHandler), Array)\\n#5 \\\/etc\\\/caddy\\\/site\\\/owncloud\\\/lib\\\/base.php(907): OC\\\\Route\\\\Router->match('\\\/occ\\\/config:lis...')\\n#6 \\\/etc\\\/caddy\\\/site\\\/owncloud\\\/index.php(39): OC::handleRequest()\\n#7 {main}\",\"File\":\"\\\/etc\\\/caddy\\\/site\\\/owncloud\\\/lib\\\/private\\\/appframework\\\/utility\\\/simplecontainer.php\",\"Line\":89}","level":3,"time":"2016-10-28T15:08:25+00:00","method":"POST","url":"\/index.php\/occ\/config:list","user":"--"}
{"reqId":"5HqHUKHcueycs76CDrbY","remoteAddr":"193.124.178.6","app":"index","message":"Exception: {\"Exception\":\"OCP\\\\AppFramework\\\\QueryException\",\"Message\":\"Could not resolve OCA\\\\Core\\\\Controller\\\\OccController! Class OCA\\\\Core\\\\Controller\\\\OccController does not exist\",\"Code\":0,\"Trace\":\"#0 \\\/etc\\\/caddy\\\/site\\\/owncloud\\\/lib\\\/private\\\/appframework\\\/utility\\\/simplecontainer.php(104): OC\\\\AppFramework\\\\Utility\\\\SimpleContainer->resolve('OCA\\\\\\\\Core\\\\\\\\Contro...')\\n#1 \\\/etc\\\/caddy\\\/site\\\/owncloud\\\/lib\\\/private\\\/appframework\\\/app.php(97): OC\\\\AppFramework\\\\Utility\\\\SimpleContainer->query('OCA\\\\\\\\Core\\\\\\\\Contro...')\\n#2 \\\/etc\\\/caddy\\\/site\\\/owncloud\\\/lib\\\/private\\\/appframework\\\/routing\\\/routeactionhandler.php(45): OC\\\\AppFramework\\\\App::main('OCA\\\\\\\\Core\\\\\\\\Contro...', 'execute', Object(OC\\\\AppFramework\\\\DependencyInjection\\\\DIContainer), Array)\\n#3 [internal function]: OC\\\\AppFramework\\\\routing\\\\RouteActionHandler->__invoke(Array)\\n#4 \\\/etc\\\/caddy\\\/site\\\/owncloud\\\/lib\\\/private\\\/route\\\/router.php(276): call_user_func(Object(OC\\\\AppFramework\\\\routing\\\\RouteActionHandler), Array)\\n#5 \\\/etc\\\/caddy\\\/site\\\/owncloud\\\/lib\\\/base.php(907): OC\\\\Route\\\\Router->match('\\\/occ\\\/config:lis...')\\n#6 \\\/etc\\\/caddy\\\/site\\\/owncloud\\\/index.php(39): OC::handleRequest()\\n#7 {main}\",\"File\":\"\\\/etc\\\/caddy\\\/site\\\/owncloud\\\/lib\\\/private\\\/appframework\\\/utility\\\/simplecontainer.php\",\"Line\":89}","level":3,"time":"2016-10-28T15:08:25+00:00","method":"POST","url":"\/index.php\/occ\/config:list","user":"--"}
Integrity status for oC9+
Technical information
them.
Results
- core
	- INVALID_HASH
		- core/application.php
		- core/controller/occcontroller.php
		- core/routes.php
	- EXTRA_FILE
		- core/application.php.rej
		- core/routes.php.rej
		- core/controller/occcontroller.php.rej
		- updater-904-905.patch
Raw output
Array
    [core] => Array
            [INVALID_HASH] => Array
                    [core/application.php] => Array
                            [expected] => 24d6ccdb10deb0245a5a3eed6a175278a1470ac65e33968ee3c0dfbdbf87bbb696d1c5357672b01e67c1fadd288a41dac73d7171e3b4dd39e8fc8964c96bdbe2
                            [current] => 245fd3078236f219bf2044b05ab6b725a9e8dc26460ffc43758022ef22c2e71016a63fbc5b1ab21609e8ceb8f80719e685cc49361a1de48091847ec6187fb1f4
                    [core/controller/occcontroller.php] => Array
                            [expected] => 2e373acef32cdca473ac3f01282ad2f52901f36a9daa8457f1e368805e5184d1b8f6f9c3f1bb1548823a8cbeb9c1ded92ec0f9b37ac83fad585276492ca8cb63
                            [current] => 173619becc129ae7e3eefefd8d3b66e5f7c6602bbe46d030b55f8be23f08eaa7b34397b9fa5fdeb8e31a333cac8f1f9f3220566859c12f11ad0dc0c7aae44da7
                    [core/routes.php] => Array
                            [expected] => 14dfd494a129d0c2e02ce7abe2c52d462d3235da88f8c2b2643fe41ebcdf987fdbeb9c90716ada826a0b2fc0affc8e8ebbd5c5d4eb1f93ee617c4ea8f68eee2c
                            [current] => 0e3e2a768b41fd4fd8f9dd46218d6c3fe27aa080992de9cab0052a434524782261fdce45d614be74049b94aef7e6872d3fd59c9451fa92eb37046e5b3a73c1ac
            [EXTRA_FILE] => Array
                    [core/application.php.rej] => Array
                            [expected] =>
                            [current] => c95c0b1cfc8a29288f6446e61ce4e838068b325b30b9fbac8a04fa2b860b69661e09b577826bc706230fceb3fccaa20aa2a8f9a6fc143b1b5106505303e13db1
                    [core/routes.php.rej] => Array
                            [expected] =>
                            [current] => d9913b981abb68db6ed14fa15052320656a3e10dea63d1d8c7684c217b8fba5fa900e86af673f5654fd066943043475ccefbc48ffad6ece4bb32a8ef337de23a
                    [core/controller/occcontroller.php.rej] => Array
                            [expected] =>
                            [current] => ed027a46864dec4b7512c1bb57cbc959dead6f59d9add47a9dde973ea0bce529285d418ee5ea2b4208c82a2ee9ecb218dfd1d92d2ed95ab19a112579a881d569
                    [updater-904-905.patch] => Array
                            [expected] =>
                            [current] => fa7b63ce4223b9d9b139bb2c69cc4c66d06fd3abc5a890def397ade9dea92e9748383489e2acd5e7ef7fb2511b052b6d1c899a562948deea84be2fd8bdd04eda
just don’t rely on the updater app. In the time you’re fiddling around with the patch and the updater app you could have done a manual update to 9.0.5
The problem is:
# sudo -u caddy php occ upgrade ownCloud is already latest version
occ upgrade will never check for updates or install updated files for you. It just runs the final database upgrade routines as explained at various documentations.
See the documentation available here how to do the manual steps:
