I recently upgraded to 8.2.7 After that I constantly got an error when syncing my files with the server. I relates to a .PST file that is over 2Gb. Before, V8.2.1.4, it synced without problems
The desktop client says:
…xxx.pst-chunking-8617289978-186-185 - server replied: Service Unavailable
The log on the server says:
Exception: {“Message”:“HTTP/1.1 423 "Backup/Documenten/Outlook-bestanden/johan.dewit@chello.nl.pst-chunking-861728978-186-185" is locked”,“Exception”:“OC\Connector\Sabre\Exception\FileLocked”,“Code”:0,“Trace”:“#0 /home/deb48734/domains/familiedewit.net/public_html/cloud/3rdparty/sabre/dav/lib/DAV/Server.php(1053): OC\Connector\Sabre\Directory->createFile(‘johan.dewit@che…’, Resource id #113)\n#1 /home/deb48734/domains/familiedewit.net/public_html/cloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php(513): Sabre\DAV\Server->createFile(‘Backup/Document…’, Resource id #113, NULL)\n#2 [internal function]: Sabre\DAV\CorePlugin->httpPut(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#3 /home/deb48734/domains/familiedewit.net/public_html/cloud/3rdparty/sabre/event/lib/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#4 /home/deb48734/domains/familiedewit.net/public_html/cloud/3rdparty/sabre/dav/lib/DAV/Server.php(469): Sabre\Event\EventEmitter->emit(‘method:PUT’, Array)\n#5 /home/deb48734/domains/familiedewit.net/public_html/cloud/3rdparty/sabre/dav/lib/DAV/Server.php(254): Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#6 /home/deb48734/domains/familiedewit.net/public_html/cloud/apps/files/appinfo/remote.php(56): Sabre\DAV\Server->exec()\n#7 /home/deb48734/domains/familiedewit.net/public_html/cloud/remote.php(137): require_once(‘/home/deb48734/…’)\n#8 {main}”,“File”:“/home/deb48734/domains/familiedewit.net/public_html/cloud/lib/private/connector/sabre/directory.php”,“Line”:121}
What can I do? (I’m not an php expert)
regards,
Johan
