File is locked - how to unlock
You can’t access files because they are locked and you find such errors in your logfile:
{"reqId":"0DijSqEkfOg2iyh9VD8J","remoteAddr":"xx.xx.xx.xx","app":"webdav","message":"Exception: {\"Message\":\"HTTP\\\/1.1 423 \\\"path\\\/file.extension\\\" is locked\",\"Exception\":\"OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Exception\\\\FileLocked\",\"Code\":0,\"Trace\":\"#0
If you’re running the ownCloud 8.2.x branch make sure that you’re using at least 8.2.2 (previous versions had a bug causing this issue).
Manually disable locking state:
  • put ownCloud in maintenance mode: edit config/config.php and change this line:
    'maintenance' => true,
  • Empty table oc_file_locks: Use tools such as phpmyadmin or connect directly to your database and run:
    DELETE FROM oc_file_locks WHERE 1
  • disable maintenance mode (undo first step).
Automatically reset locking state:
Normally ownCloud should reset the locked state on its own via background jobs. So make sure your cron-jobs run properly (you admin page tells you when cron ran the last time): https://doc.owncloud.org/server/9.0/admin_manual/configuration_server/background_jobs_configuration.html
Permanent solution (if it happens regularly)
Fehler - File ist locked - kein Sync
Can't delete files
Problems to upload 2 GB+ files
My files aren't syncing the way I would expect. How should I troubleshoot?
After upgrade to 8.2.1.4 error when syncing big fil
Benutzer kann geteielte Datei nicht löschen
Locked File in Owncloud version 10
File Locked / Datei kann nicht gelöscht werden
Trouble Syncing Files
Could not move folder
Popup keeps informing me on error
Owncloud Sync error lock-unlock files
ownCloud ignore my MP4 and .rar files on sync
Issues deleting my folders and files on an encrypted profile (OC10.x)
Lock files issues - 65K entries in table oc_file_locks
Cannot files:scan a user
After update to 9.1.2 some files have a yellow exclamation mark
Errors when running sudo -u www-data php occ files:scan --all --repair
Error uploading files larger than 40gb
423 locked file when trying to update
Couldn’t move (foldername)
Error 423 Owncloud
Server refuses to delete some files
[Terminé] Erreur à la Suppression du fichier
[Résolu] Server replied: locked
File Locked, how to reset using docker
Error deleting last empty folder
Too many files on /data compared to local drive
OwnCloud - Error log
Shared folders are not sync with the Desktop Client
Owncloud & Docker : Unable to run CLI correctly
Problem restoring files
Mailbird on ownCloud
Can not delete one file!?
Owncloud newbie needs help desperatly
Login impossible after downgrade to 8.2
