1.Changed file extension from .jpg to .pdf
2. File locked, wont unlock
File(s) shouldn’t lock.
File(s) locked
OSX 10.13.6
Docker 18.06.1
10.0.10
<script src="https://gist.github.com/Jared944/297278e4468dce691f1cfa9c7d1ae967.js"></script>
<script src="https://gist.github.com/Jared944/e35f9b4e2e6a043af180cff07646a639.js"></script>
Are you using external storage, if yes which one: local/smb/sftp/… No
Are you using encryption: No
I found this link that shows the steps to unlock a file :
Though I do not know how to do that through docker. I’m not amazingly adapt at command line. Any help would be appreciated.
Thanks,
Jared
