I have cross-posted this issue to StackOverflow (since it is more of an apache issue than owncloud issue):
I have deployed OwnCloud 8 on a Ubuntu 14.04 instance to the domain box.example.com. I would like to host some static html on the same VM and have apache point project.example.com to it at /var/www/html.
In apache the file /etc/apache2/conf-available/owncloud.conf was created by OwnCloud containing:
#I changed the first line as follows
##Alias /owncloud "/var/www/owncloud/" # commented out
Alias / "/var/www/owncloud/"
<Directory "/var/www/owncloud">
Options +FollowSymLinks
AllowOverride All
<IfModule mod_dav.c>
Dav off
</IfModule>
SetEnv HOME /var/www/owncloud
SetEnv HTTP_HOME /var/www/owncloud
</Directory>
How can I add a new subdomain VM in apache so that I’ll have two working sites: box.example.com and project.example.com. So far with everything I have tried project loads the OwnCloud front-end and does not open the static html.
Do I need to touch /etc/hosts?
box.example.com loads my OwnCloud 8 front-end.
project.example.com loads static html at /var/www/html/index.html
project.example.com loads OwnCloud 8 front-end.
Operating system: Ubuntu 14.04
Web server: Apache
PHP version: PHP 5.6.21-1+donate.sury.org~trusty+4 (cli)
ownCloud version (see ownCloud admin page): 8.1.9 (stable)
