- Attempt to connect using the url: ‘https://cloud.domain.com’
when the url: ‘cloud.domain.com’ is requested, display the ownCloud panel similarly to how domain.com/owncloud operates. Display the url: “https://cloud.domain.com/” hide “index.php”
Example: “https://cloud.domain.com/settings/”
When the subdomain ‘cloud.domain.com’ is requested, the website is either not found or has an SSL error. domain.com/owncloud works perfectly; however, I would like to move to the subdomain: ‘cloud’ and slowly, but surely shorten the url for ownCloud services.
I’m using a shred web-server provided by InterServer in tandem with CloudFlare:
Operating system: Linux
Web server: Apache 2.4.29
Database: MySQL 10.1.32-MariaDB
PHP version: 5.6.34
ownCloud version: 10.0.7.2
Updated from an older ownCloud or fresh install: Fresh Install
Where did you install ownCloud from: ownCloud Web Installer (official website)
Signing status (ownCloud 9.0 and above): No Errors
"instanceid": "ocwri8nq6q9k",
"trusted_domains": [
"domain.com",
"cloud.domain.com"
"datadirectory": "\/home\/user\/public_html\/owncloud\/data",
"overwrite.cli.url": "https:\/\/domain.com\/owncloud",
"dbtype": "mysql",
"version": "10.0.7.2",
"dbname": "chillser_owncloud",
"dbhost": "localhost",
"dbtableprefix": "oc_",
"logtimezone": "UTC",
"installed": true,
"mail_smtpmode": "smtp",
"filelocking.enabled": true,
"htaccess.RewriteBase": "\/owncloud"
Full Report: Config Report - Pastebin.com
Admin Config Report
Deleted files
Federation
Provisioning API
Share Files
Update notification
Versions
Collaborative tags
Comments
First run wizard
Mail Template Editor
Market
Notifications
Video Player
Are you using encryption: Not yet (No)
I’ve been researching this for days and all other related threads I’ve been able to find are either dead with no solution or the solution doesn’t mean anything to me. All I would like is for the ownCloud services installed on my web-server to be redirected to the subdomain ‘cloud’ rather than a directory in the url. the main directory of the url is a website.
I have experimented with a records and cname records in CloudFlare, but can’t find the right configuration. What is the correct dns record for cloud.domain.com?
I can’t find any guides or information regarding running ownCloud in a subdomain. What is the correct configuration for doing this? Is there a guide?
Here are some similar threads:
apache-conf-setup-to-serve-subdomain-site-alongside-owncloud-deploy
