Can't import root certificate on qnap system using qpkg installation
  1. I added enable_certificate_management in to my config.php, and see the “import root certificate” in the config page.
  2. I imported my self-made certificate
the root certificate works and I could enter my owncloud via https
I can’t enter my owncloud via https, the imported certificate just disappear after I refresh the config page.
PHP version: I don’t really know the above. I downloaded the latest version from qnap app center, linked it to mysql according to the discription.
ownCloud version: (see ownCloud admin page) 10.0.10.4
Updated from an older ownCloud or fresh install: fresh installed
thank you for your help.
Hi LULUZ,
[deleted apache vhost comment]
Edit: I overlooked the qnap-Part. Maybe you should put qnap in the title and be a little more specific about your system, so fellow users may help you.
How did you set up ownCloud in the first place? Did you follow this documentation? ownCloud on QNAP :: ownCloud Documentation
hello, thank you for replying.
I am sure I installed owncloud following the instruction. and it worked pretty fine with http. I even shared some files to my friends and nothing wrong.
some more information.
I ssh to my nas and find the certificate uploaded in this location.
/share/CACHEDEV1_DATA/.qpkg/owncloudv10/data/files_external/uploads
there is also a certificate called rootcerts.crt in
it’s much bigger, but I don’t know the difference.
Unfortunately I never worked with a qnap, so I can only offer best guesses.
It looks like ownCloud comes in a docker for qnap. For dockers it is quite usual to have an external nginx/apache/… performing the SSL termination and proxying plain HTTP to the docker port (in the appliance). Are there any settings in the frontend to accomplish this? Maybe this is an option for you? In this case you shouldn’t have to import any certificates.
FYI regarding the multiple occurrence of rootcerts.crt, the one in the files_external folder is shipped with ownCloud itself, the one in the files_external/upload is the one imported by you.
I admit, the documentation available on the web on both the qnap and the ownCloud side is very poor, especially when there was this big press release back in 2020: QNAP Systems Inc. and ownCloud GmbH announce strategic partnership - ownCloud
@dmitry I see there is some documentation at ownCloud on QNAP :: ownCloud Documentation but this does not cover any certificates at all. Do you know some “insider” who could add the relevant lines? - or - is this as @anon21401411 wrote at [1] that “i think the Qnap NAS app isn’t provided by the ownCloud people so this could be the reason why no one was able to answer / help here yet.
thank you. I tried nginx in docker and it worked well. it really solved my problem.
Hello @cortho
Thank you for the helpful response and notifying me about this issue. I have forwarded it to the proper channels. I hope we can improve our documentation and avoid issues like this.
Best Regards
Dmitry
Hello @LULUZ,
I assume you’re referring to the ownCloudX app from the QNAP app store like showed in the following screenshot!?
Actually this app is not maintained by us and will be removed from the app store by the original maintainers when our ownCloud app is ready. We are currently working on that together with QNAP. That’s also why ownCloud on QNAP :: ownCloud Documentation is not applicable for your current installation.
You already can try our app by downloading it from https://github.com/owncloud/qnap-packaging/releases (in the assets section), but there is not yet an official release. Since we are also using the QNAP proxy in front of the new ownCloud app, these manuals apply How to Use SSL Certificates to Increase the Connection Security to your QNAP NAS | QNAP or How to purchase and use myQNAPcloud SSL certificates? | QNAP to exactly your problem.
