CardDav not syncing with SSL Proxy in use
On Owncloud 9.1.0 Installation Contacts dont sync for me with i phone. I nailed down the problem to the ssl proxy which is sslsites.de offered by my webhoster. When i turned off ssl proxy all worked fine.
it seems the user name and password isn´t submitted correctly
Exception: {“Message”:“HTTP/1.1 401 No ‘Authorization: Basic’ header found. Either the client didn’t send one, or the server is mis-configured, No ‘Authorization: Basic’ header found. Either the client didn’t send one, or the server is mis-configured”,“Exception”:“Sabre\DAV\Exception\NotAuthenticated”,“Code”:0,“Trace”:“#0 [internal function]: Sabre\DAV\Auth\Plugin->beforeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#1 /kunden//cloud/3rdparty/sabre/event/lib/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#2 /kunden\/cloud/3rdparty/sabre/dav/lib/DAV/Server.php(446): Sabre\Event\EventEmitter->emit(‘beforeMethod’, Array)\n#3 /kunden\/cloud/3rdparty/sabre/dav/lib/DAV/Server.php(248): Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#4 /kunden//cloud/apps/dav/lib/Server.php(169): Sabre\DAV\Server->exec()\n#5 /kunden//cloud/apps/dav/appinfo/v2/remote.php(29): OCA\DAV\Server->exec()\n#6 /kunden\/cloud/remote.php(164): require_once(‘/kunden/114828_…’)\n#7 {main}”,“File”:“/kunden//cloud/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php”,“Line”:188,“User”:false}
could anyone give me please a hint how to configure this right?
If you control the ssl-proxy, you can fix the settings:
Do you have any option to modify for the ssl-redirect?
think i cant modify the proxy itself as it is the standard of my shared hosting
You could also have a look at proxy specific settings of oC like described here:
from this lines
“trusted_proxies” => [‘10.0.0.1’],
“overwritehost” => “ssl-proxy.tld”,
“overwriteprotocol” => “https”,
“overwritewebroot” => “/domain.tld/owncloud”,
“overwritecondaddr” => “^10.0.0.1$”,
only trusted proxy and last one i didnt have in my config.
i need to speak with my hoster for the ip of sslsites and verify later if this helped
inserting the ip didnt change the problem
changed from ssl proxy to a real ssl certificate but still no sync of contacts
i also tested to connect to cloud with windows explorer connecting trough webdav but then a windows opens asking for username and password - but it doesnt accept the userdetails
How can i test at what point the userdetails get lost?
there is a larger FAQ describing all known information about such WebDAV issues which might happen within your environment:
Good Morning
A big thank you Real Rancor for the time you spend to try to offer an answer.
I myself spend a couple of hours to try all of them just finding out the majority of proposals to change code are outdated because they relate to old versions of owncloud.
Don´t take this as an offend your help is very much appreciated.
At this point i can say the solution to my problem was the very last i wanted to try:
I deleted Owncloud and also the Database. Upload the recent version and made a fresh start—> e´voila now it works.
